Question about NEC LT30 Multimedia Projector
NEC LT30 - Lamp dosen't turn on.
When i turn on my NEC LT30, it trys to start op, but after 30 sec. it goes to standby mode and the status indicator is blinking red. According to the troubleshooting in the manual, the problem is: "Lamp Error" "Lamp fails to light. Wait a full minute and then turn on again".
But this dosen't seem to work at all no matter how many minutes i wait. I've also tryet to press the "Power ON" button in 10 sec. to reset the lamp. But with no luck. The lamp dosen't seem to be broken at all when i look at it.
Somebody who have a solution to my problem?
Thanks
Morten
  • 3 more comments
  • Ruskjaer Mar 18, 2008
    If i can't get any picture and i tryed to press the "Power ON" button for 10 secs. then how can i reset lamp hours?
  • DaveMcCall Apr 17, 2008
    My NEC LT30 is also giving the "Lamp Error" code. I've tried re-seating the lamp, unplugging and holding down the power button to clear the residual charges on the circuitry, and even a new lamp. All with the same results. There is no power switch or reset button on this model. Just a power/standby button. I was digging through the user manual to see if there is a button combo for a "hard reset" to the manufacturer's original settings, but I couldn't find one. I also looked for a service manual for this model, but I'm only finding the user manual. HELP!
  • Anonymous Jun 12, 2008
    I'm having the same problem. After the machine attempts to start up, i get the blinking red status light (6 times). The manual says just to wait 1 minute and restart, doesn't work. It seems to work once if i take out and then replace the bulb, but only once, then i have to do it again.
    The solution below didn't help. First of all, the lamp must be on to get to the menu to reset the lamp hours. After doing that, it worked twice, but then blinky status light and no lamp again.
  • andy bell Oct 26, 2008
    i am having the same problems as above. however i am unable to reset the lamp hours as i have lost the control. can it be done without the remote.
    any ideas
    andy
  • jamie439 Dec 09, 2008
    is there any way of doing this without the remote control?
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Posted on Oct 22, 2008
  • 25 Answers
We have had this problem with two of these. The first one was repaired by replacing the ballast board (NEC P/N 03N-10-0763), but the second one must have other problems, as replacing this part did not help.
Posted on Jul 13, 2010
  • diaboardic Nov 27, 2010
    same here.. PLEASE does any one know where to find service manual ???
    Problem Solver:
  • 4 Answers
Please reset lamp hrs to zero and also clean air filter located at bottom of projector
Posted on Mar 17, 2008
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
How can I reset a VT540 without a remote it has steady orange and red lights on so is in standby after bulb change
Simple.
Press the Help button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the STATUS indicator goes out.
Apr 04, 2011 | NEC MultiSync VT540 Multimedia Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
NEC LT30 Multimedia Projector Logo
3,624 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
