Loosing sound / distortion
My Legacy Series II amp, model LA 1020 has two problems. 1)The subwoofer is bridged and now won't play unless I play with the crossover switch. It will operate for a minute or so, then shut off. Ive checked connections, reversed channels to eliminate the head unit (JVC digifine) 2) The unbridged side is giving me some distortion intermittently in just the right channel. Again I have reversed the channels, etc. as above and the problem remains in the right channel. The speakers can handle well above the stated RMS and peak levels. I removed the cover plate and used contact cleaner to try on the switches suspecting possible oxidation. The only thing I have not done yet is try to use a home audio/video amp to make double sure it is not my head unit. Any ides or is my amp (or switches) just going?
  • mcmusic1st Mar 17, 2008
    Thanks Dan. Your response confirms what I was suspecting.
    Thanks, Mike
  • 4,234 Answers
If the sub channel is shutting down, there is a problem with that channel. The unit will shutdown to prevent further damage. This unit will need to see a service bench to determine the defective part(s).
Dan
Posted on Mar 17, 2008
SOURCE:
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
CAN THE AMERICAN LEGACY SERIES 2 LA490 AMP HANDLE A 2 COILS 12'' KICKER SUBWOOFER??
yes, should be fine in series or parallel. it will run hotter under lower ohms but crank out more volume!
Jan 28, 2011 | Legacy Audio American Legacy II LA490 Car...
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
Problem with legacy amp
I would check the RCA preamp wires connecting the stereo to the amp. If these are loose or broken, it could cause you to lose your sound.
Does the amp show signs of life, such as clicking on, an LED turns on, or anything like that?
Has anything else changed between the time it worked and didn't work?
Mar 20, 2008 | Legacy - American II: 2 Channel 2000W...
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
Pv900 power amp 300 watts
Recheck your switches on the back sounds to me like you have the subwoofer crossover setting turned on.
Nov 12, 2007 | Audio Players & Recorders
Optimum sound performance needed
1) legacy products are highly overrated and i have never seen one put out the power it claims
2) if you are running the amp bridged, you need to match the impedance of the speakers to the amps highest output impedance, otherwise your system will not sound all that great...
what size fuse or fuses does your amp use? what size wire did you install with (power and ground)? did you connect direct to battery or did you connect to a fuse block or similar? did you use a stiffening capacitor? does it sound like it is clipping when you turn it up or is it just distorted? what kind of box are you using for the speakers (ported, vented, sealed, bandpass)?
if you give me the model number of your speakers and your amplifier i can probably help you more, but with the information you have provided, this is all i can offer..
hope it helps,
trin
Nov 11, 2007 | Legacy - American II: 2 Channel 2000W...
Constant thumping
Theres most likly an open ground printed circuit trace on the Printed circuit board on the bottom. first clue is You said your girlfriend disconncted and blew the fuse. You gonna have to ytake the amp apart and totally disassemble the PCB off the rails and everything unless theres a bottom cover. It may be an obvious burn or could be hidding under the green paint of a trace?? Goos luck
Jun 01, 2006 | Legacy - American II: 4 Channel 1000W...
100 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
