Question about Sony Ericsson W850i Cellular Phone
My w850i keeps terning itself off
How do i fix it
  • almalish02 Mar 26, 2008
    hi my k850i its turn off after it showing me the logo
    Brigadier General:
  • 7,752 Answers
Take the phone and have the firmware on the phone reflash....take it to a mobile service center and ahve them fix it for you.
Posted on Mar 24, 2008
SOURCE:
I Have error code E000007 - 001 on Canon C9060 pro
Fixing belt full displacement error (Displacement
direction is unknown.)
Full displacement of the fixing belt was detected, but the
displacement direction (front, rear) was unknown.
1. Forgot to clear the counter at the fixing belt
replacement -> clear the counter
2. Check physical relationship between the fixing belt
position sensor 1, 2 (PS71, 72) and the sensor flag
A. In case that both sensors are blocked from light
A-1. Faulty fixing belt unit -> replace the fixing belt
unit
A-2. Faulty fixing belt displacement control drive ->
replace the displacement control drive assembly
B. In case that both sensors are not blocked from light
B-1. The connector on the fixing belt position
sensor 1, 2 (PS71, 72) is physically removed,
or the cable is disconnected -> connect the
connector, or replace the harness
B-2. Faulty fixing belt position sensor 1, 2 ->
replace the sensor
B-3. Faulty fixing belt unit -> replace the fixing belt
unit
B-4. Faulty fixing feed driver PCB -> replace teh
B-5. Connection error of drawer connector (J8023)
-> clean or replace drawer connector
B-6. Short-circuit or open-circuit of harness
between fixing feed driver and DC controller
PCB -> replace harness
Jan 02, 2018 | Canon Office Equipment & Supplies
Km2030 showing code c610
C610 Broken fixing heater wire
• Warm-up does not end within 90 s.
• The secondary stabilization fixing
temperature drops to 100°C/212°F or
below.
• The fixing temperature remains below
40°C/104°F for 7 s or longer after the
fixing heaters have been turned on.
Causes
  • Fixing heater installed incorrectly (Check and reinstall if necessary.)
  • Broken fixing heater wire. (Check for continuity. If none, replace fixing heater.)
  • Poor contact in the fixing unit thermistor connector terminals.(Check the connection of connector CN12 on the main PCB and the continuity across the connector terminals.Remedy or replace if necessary.)
  • Broken fixing unit thermistor wire.(Measure the resistance. If it is ∞ ?, replace
    the fixing unit thermistor.)
  • Fixing unit thermistor installed incorrectly.(Check and reinstall if necessary.)
  • Fixing unit thermostat triggered.(Check for continuity. If none, replace the
    fixing unit thermostat. Check the operation of the cooling fan and repair if necessary.)
Jul 09, 2011 | Kyocera KM-1505 Copier
I got the code c610 on my copystar cs-1810, how to fix, and where i can get the manual as well
? It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
? It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
? It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Check for continuity. If none, replace the fixing unit thermostat.
May 08, 2011 | Copystar CS-1810 Copier
What is city area code of doha qatar
hello;
select your place codes with sub codes: 974284250 9741121127 XES Emergency Services 974124522094 XVM Voice Mail & SMS 97421738223 PAG Paging 9742244520 PAG Paging 974286 Fix Line MATS 9744137128 Fix Line MATS 9744289375 Fix Line MATS 9744341613 Fix Line MATS 97443041613 Fix Line Doha Central (DC3) 97443141613 Fix Line Doha Central (DC1) 97443241613 Fix Line Doha Central (DC2) 97443341613 Fix Line Doha Central (DC1) 97443441613 Fix Line Doha Central (DC2) 97443541613 Fix Line Doha Central (DC3) 97443641613 Fix Line Doha Central (DC2) 97443741613 Fix Line Doha Central (DC3) 97443841613 Fix Line Doha Central (DC3) 97444563138 Fix Line MATS 974440563138 Fix Line Doha Central (DC3) 974441563138 Fix Line Doha Central (DC1) 974442563138 Fix Line Doha Central (DC2) 974443563138 Fix Line Doha Central (DC1) 9744431599563138 Fix Line PSTN Testnummer 9744432599563138 Fix Line PSTN Testnummer 974444563138 Fix Line Doha Central (DC2) 974445563138 Fix Line Doha Central (DC1) 974446563138 Fix Line Industrial (IEC) 974447563138 Fix Line Doha Central (DC2) 974449563138 Fix Line Doha Central (DC1) 9744546098 Fix Line MATS 97446196683 Fix Line MATS 974460196683 Fix Line Industrial (IEC) 974461196683 Fix Line Industrial (IEC) 974462196683 Fix Line Airport (APC) 974463196683 Fix Line Rayyan (RYC) 974464196683 Fix Line Wakrah (WKSC) 974465196683 Fix Line Airport (APC) 974466196683 Fix Line Airport (APC) 974467196683 Fix Line Airport (APC) 974468196683 Fix Line Industrial (IEC) 974469196683 Fix Line Industrial (IEC) 97447252915 Fix Line MATS 974471252915 Fix Line Rayyan (RYC) 974472252915 Fix Line Khuratiyat (KRC) 974473252915 Fix Line Doha Central (DC3) 974474252915 Fix Line Doha Central (DC1) 974475252915 Fix Line West Bay (WBC) 974477252915 Fix Line Wakrah (WKSC) 974478252915 Fix Line Khuratiyat (KRC) 974479252915 Fix Line Khuratiyat (KRC) 974482826 Fix Line MATS 9744802826 Fix Line Rayyan (RYC) 9744812826 Fix Line Rayyan (RYC) 9744822826 Fix Line Rayyan (RYC) 9744832826 Fix Line West Bay (WBC) 9744852826 Fix Line Doha Central (DC1) 9744862826 Fix Line Khalifa Town (KTC) 9744872826 Fix Line Khalifa Town (KTC) 9744882826 Fix Line Khalifa Town (KTC) 9744892826 Fix Line Khalifa Town (KTC) 9744955072 Fix Line MATS 974507311 Mobile Mobile GSM 9745211796 Mobile Mobile GSM 97453192116 Mobile Mobile GSM 9745416281 Mobile Mobile GSM 97455548189 Mobile Mobile GSM 9745620766 Mobile Mobile GSM 9745825251 Mobile Mobile GSM 974593 Fix Line Fixed Telephone Cellular 97459383 Mobile Mobile GSM 97459393 Mobile Mobile GSM 97490097012 XAT Audio text Services
Feb 21, 2011 | Computers & Internet
Getting error code e000050000 - what is this?
Main Cause: The fixing web has been taken up. The fixing web length sensor (PS45) is
faulty. The DC controller PCB is faulty.
Fixing web
1) Is the fixing web taken up?
YES: Replace the web with a new one.
Service mode
2) After replacing the fixing web, has the fixing web counter been reset
in service mode (COPIER>COUNTER>MISC>FIX-WEB) ?
NO: Reset the counter.
Fixing web length detecting lever.
3) Is the position of the web length detecting lever correct?
YES: Correct the position of the lever.
Fixing web length sensor (PS45), DC controller PCB
4) Is the fixing web length sensor normal? (See the instructions on
how to check the photointerrupters.)
NO: Replace the sensor.
YES: Replace the DC controller PCB.
Feb 04, 2011 | Canon imageRUNNER 5000 Copier
E000007-0000 errorquick solution in IR 2200 Canon printer
Fixing film rotation error
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause: The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO: Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal: 5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440
msec OFF
NO: If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
NO: Replace the DC controller PCB.
Jan 27, 2011 | Canon (6981A002AA) for imagerunner 2200,...
I have canon ir 5800cn error 014 please any help
There is service bulletin that says:
Measures against noise, E014, and faulty fixing caused by coming off of fixing roller
Detail:
<Symptom>
The fixing roller comes off, leading to noise, E014, and faulty fixing.
<Cause>
Because the fixing spacer [2] does not rotate while the fixing roller [3] is rotating, the retaining ring [1] becomes
detached due to frictional resistance with the fixing spacer, and the fixing roller comes off as a result.
<Factory Measures>
A projection (P-2 [1]) is added to the fixing spacer. When attaching the fixing spacer, fit the projection in a
groove (P-3 [2]) of the fixing roller shaft so that the fixing spacer will rotate together with the fixing roller and
frictional resistance between the fixing spacer and the retaining ring will be eliminated. Therefore, the retaining
ring is prevented from becoming detached.
Service Work:
Replace the fixing spacer with the new-type fixing spacer when the foregoing symptom has occurred in the
field.
To prevent occurrence of the symptom, check the shape of the fixing spacer when replacing the fixing roller,
and replace with the new-type fixing spacer if the previous-type fixing spacer is attached.
<Point to note on attaching the fixing spacer>
Fit the projection (P-2 [1]) in the groove (P-3 [2]) of the fixing roller shaft to attach the fixing spacer.
OLD SPACER, FIXING FC5-2590-000
NEW SPACER, FIXING FC5-2590-020
Affected Machines:
iR C6800 EUR 230V JKH01022 and later
iR C6800N EUR 230V JKP02113 and later
iR C5800 EUR 230V KEN00106 and later
iR C5800N EUR 230V KES00135 and later
This is factory error, and I think that you must call service and have it fixed under warranty.
Hope that helped
Jul 01, 2010 | Canon Office Equipment & Supplies
What changes have been done to the latest firmware for my DI-604 and DI-614+?
V3.36 (DI-604 RevE only): Fixed minor interface bugs V3.38 (DI-604 RevE only): Fixed issue with non-standard FTP port function Fixed issue with WAN speed selection feature Fixed issue with Stats page - showing 0 transmitted packets Fixed minor Virtual Server bug V3.39 (DI-604 RevE only): Add WAN speed selection option - defaults to 10Mbps Fixed dial on demand/idle time bug Fixed Asheron´s Call II reboot issue Fixed Static DHCP/MAC filter clone issue Fixed Virtual Server entry bug
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Sony Ericsson W850i Cellular Phone Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
