Question about Intel Motherboard
Mic dont work
I have a A8V-Vm series motherboard..I downloaded all of the drivers butwhen I try and use my mic it wont work. Why not? I even bought a newmic thinking my old one was broken but it still isnt working. Am Idoing something wrong?I want to know the way to plug de mic on the motherboard?
tanks luis
    President:
  • 2,351 Answers
Luis_antonio, did you try to set your mic up from within windows?
Do this, open control panel, than open sound and audio devices. Click on the voice tab, click on the test hardware button.
Follow the on-screen instructions. Do you have mic?
There is no direct connection to the board. There is a connection for a front mounted case sound & mic connector if your case has this feature but chances are if your mic does not work connected to the rear of the board it will also not work with the front connector/jack.
Let’s check two other places first. While having opened the sound and audio devices window, click once again on the Voice tab if not already opened. Notice the Default device, (the name of the device). Click the Audio tab listed there is a Default device, (name of device). They should be named the same. Click cancel to close that window. Than open the system icon. System Properties will open. Click the hardware tab, than click the device manager button. Scroll down the list to Sound, video and game controller. Click the + sign & all the audio devices will open for you to see. Do you see a yellow ! point? If yes your sound device software needs to be re-installed. If no & you see a device named ADI AD1986A SoundMAX or AC97, than your current sound device is setup correctly. This device name above should match what you saw while in control panel's sound and audio devices. If after doing another reinstall & running the setup for mic through windows control panel still fails than the integrated sound chip on the motherboard is defective. If your board is under Asus three year warranty, return for a replacement board. If your warranty has timed out, than buy a PCI sound card & install onto a opened PCI slot.
Good Luck!
Have more questions? Feel free to ask.
Mike
Posted on Mar 24, 2008
I want to update my Asus A8V-VM Bios...model: A8V-VM
You can find all the drivers, bios, information for the Asus A8V-VM HERE.
The link to download the BIOS and BIOS-utility HERE, after selecting the used OS.
Sep 19, 2011 | ASUS A8V-VM Motherboard
How can i get vga driver for asus a8v-vm motherboard
Go to asus.com and go to support and downloads driver and select appropriate modelnumber of your laptop and windows version and download it its simple
Apr 18, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
SOUND DRIVE THAT SUPPORTS WINDOWS7
go to the Asus websitr version of windows.e to download the correct driver for you
May 27, 2009 | ASUS A8V-VM Motherboard
Problem regarding audio driver of ASUS
Go to asus web site,give specs and download mother board chip set drivers. Or try just the audio driver.
Jun 19, 2008 | ASUS A8V-VM Motherboard
Mic issues
A8V-VM SE FRONT PANEL AUDIO does not work. The back panel audio speaker port works ok but not the MIC port. I have built over 100 pcs with different motherboards & procesors including several other Asus MoBo both Intel and AMD types. BIOS flas did not help. Asus tech support /knowledge base is useless to find answers.
If anyone has had this problem and solved it , please pot your answer.
Thanks
Oct 22, 2007 | ASUS A8V-VM Motherboard
Intel Motherboard Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
