Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload Washer (MAH5500B)
We washed a load the other day and went to get the clothes out and my wife noticed that the washer had no power.  It had blown a breaker, so I reset the breaker, and it immediately blew the breaker.  So I unplugged the machine for a bit and tried it again, this time I was standing next to the machine.  It clicked very loudly several times and blew the breaker.  The door had been locked shut during all of this, I was able to remove the detergent dispenser and release the door lock and get the clothes out.  But I can't get the washer to not blow the breaker.
What is my next step?  What do you think is wrong?
Thanks for any help
    New Friend:
My older Maytag Neptune has refused to spin off and on for several years. At first slamming the door worked, now nothing does. The drum rotates the same way it does for washing during the spin cycle.
Posted on Apr 11, 2011
    President:
  • Maytag Master
  • 2,651 Answers
You def have a direct short somewhere, try remiveg the 3 screwsfrom the top of hte console and tipping foward you ll see a cintrol boardand some wiring look for the "arcing" mark or wire off causing short.
Posted on Mar 20, 2008
6ya staff
SOURCE:
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag frontload washer won't spin the water out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water sits in bottom- does not drain all of water. Frontload Neptune washer
level sensor,drain time off,level might be reading empty while still at level check manuel to see if some kind of level indicator exists
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Timer Problem for the Maytag Neptune Front Loader Washer.
could be as simple as unplugging it for 10 seconds to reboot the control.
Oct 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
