Question about Sony KP-53S65 53" Rear Projection Television
Sony KP-53S63 problem
No picture, red power light continuously blinking, electrical burn smell
  • 1 more comment
  • jtyrone Mar 17, 2008
    constant blinking about once a second see smoke on left center of main circuit board appears to be a small capacitor
    HELP please
  • Anonymous Jan 13, 2009
    KP53S65 SONY Rear projection TV
    stopped working. Pop noise followed by burning smell, no picture and no
    sound. Red light by power button blinks. read on-line posssible
    capacitor or board. Need to know how to fix myself if possible or what
    to look for in repair. Thanks
  • Jeff Workman
    Jeff Workman Jan 26, 2009
    model KP53S65 popping noise heard and electrical burn smell, fuse still good on power board, blinking light but no picture. and power button activates what sounds like a relay.
    President:
  • 4,402 Answers
How many blinks pause then blink?
Posted on Mar 17, 2008
No picture comes up but tv powers up and the stand-by light blinks for about 3 to5 seconds, i also hear sound when i turn it on and change channels
If in shutdown the power light should continue to blink a specific number of blinks which is a error code.
This set is prone to bad picture tubes (has 3) so depending on code may be a fatal issue----sets will before flash bright red, green, or blue when this happens and shut off.
Jun 14, 2012 | Sony KP-51HW40 51" Rear Projection...
My sony kp-53v35 keeps immediately shutting itself off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
Mar 22, 2012 | Sony KP-53V35 53" Rear Projection...
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
With sound but no video only raster with vertical lines
The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
Apr 08, 2009 | Sony KP-FX532M91 TV
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
