Question about GE WBSR3140DW Top Load Washer
Water not draining - GE WBSR3140DW Top Load Washer
  • oucrimson23 Sep 27, 2008
    I have the same exact problem. Except I have a Kenmore 90 Series Washer.
I had this same issue... most likely (and if you are lucky) it is the switch for the lid. If you don't hear a solid click sound when you shut your lid the swich is not connecting and on telling the machine to drain or move on to the spin cycle. You need to replace the part.
Posted on Oct 17, 2008
  • Anonymous Oct 17, 2008
    I am sorry, I read that wrong. If it is spinning but not draining then it is likely your pump.
  • GE Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Dec 19, 2011
My ge washer is not draining the water. it is spinning but not draining. i took out all the clothes and put it on spin and drain but the water wont drain out. what can i do? can i fix it myself? or do i have to call someone? please help asap!!!! thanks!
Mary
Posted on Jul 12, 2008
SOURCE:
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Not washing dishes
check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Mar 06, 2010 | Dishwashers
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
GE WBSR3140DW Top Load Washer Logo
915 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
