Question about Altec Lansing ADA995 Speaker
Dented front speaker grills.
Altec Lansing ADA 995
Anyone know how to remove the grill from the Satellite and Centre speaker which have been dented. Speakers supplied with a Dell Dimension PC.
Thanks
Reg
Take a good size paper clip, make it into an L shape and stick it in one of the holes at the dent, be careful not to hit the speaker. Turn the lower end of the L so it is flat, up against the grill and put gently to straighten out the grill. the other solution is to take the whole speaker apart and push from the inside.
Nogenius54.
Posted on Mar 17, 2008
    Genius:
  • 2,985 Answers
Usually a push fit , so gentle leverage with a knife blade perhaps.
But if the grill is metal then undoing the damage may not be worth the attempt because working the metal will almost certainly stretch it and make it worse.
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
Ada 104
I doubt that a cheaper one will work. Unlikely they would build in compatibility with A L speakers.
Apr 11, 2014 | Altec Lansing Audio Players & Recorders
I want to connect ADA-995 speaker system to stereo
You don't. They're already amplified via the amp that's inside the subwoofer. They're only designed for a headphone output on a PV or portable audio player
Apr 03, 2014 | Altec Lansing Audio Players & Recorders
I can't find a driver download for Altec Lansing ADA-310 computer speakers
You can find the drivers in the website of Altec.
David
Mar 03, 2013 | Audio Players & Recorders
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
How to open altec 251 speaker right front one
first remove the net from the sides.then just above the controls of the speaker.there is a super glued joint where the two colors are combines..gently open it by screwdriver.i have opened it.put the screwdriver between the colored joints and push it down gently.
it will definitely work.
Jan 16, 2011 | Altec Lansing ACS 251 Computer Speakers
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
Altec Lansing ADA 885
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA995 Speaker Logo
255 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
