MINOLTA EP3170 PRODUCES BLACK INK STAINS ON PAPER
My ep3170 copier is producing all black paper output. i have tried cleaning but it hasn't solved the problem. can some help me on this.
  • ddanel Mar 17, 2008
    thank you
  • 1,326 Answers
Heres a few ideas for you... Do you get a error code? Dose the scanning lamp turn "On" How about is the primary corona unit in all the way? If the scanning lamp does not come on you have a blown lamp or thermal fuse. Do you get a small part of a image? It could be that the power cable for the scanning lamp is cut or broken ? It is a older model of Minolta, but one of the better ones. It could also be the primay corona unit is not in all the way. Or what use to happen is that the Grid would fall off the unit. It looks like a metal grid, it could also be the post corona wire is broken. It could also be the HVTDC pcb, but you have transfer current. It could also be the primary Block in the back of cth developing unit. I would start with the simple stuff first. Goog Luck
Posted on Mar 18, 2008
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Printer produces a poor copy
remove cartridges , take a q-tip w/alcohol and clean out ink ports where they drop ink onto the paprer the ports could be clogged with dry ink , thus preventing the new ink from reaching the paper. after you clean out the ink ports re-install the cartridges, and do alignment proceedures again this time color should be restored
Jul 11, 2009 | Lexmark X2250 All-In-One InkJet Printer
Black splatters all over paper
Have you changed the cartridge? Sounds like a bad seal after it was refiled or the nozzle went bad on the black ink. Try replacing the cartridge.
Jul 08, 2009 | Office Equipment & Supplies
Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Jun 25, 2009 | Canon Pixma MP500 All-In-One InkJet...
Do not know what Kind of color cartrige does a Minolta EP 3170 us
Good luck finding the separate developer units for this obsolete machine if you don't already have them.
If your just looking for color toner you may get lucky doing an internet search for the following item number: 8916361 - BLUE TONER
Jun 16, 2009 | Minolta Office Equipment & Supplies
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
161 people viewed this question
jasbo
jasbo
