Question about 2wire 2700HG-B Router (2700HGB)
Computers, modems,printers I have 2 problems.#1 i have a 2wire2700hg-e modem and a canonmx310 printer,fax copier.I would like to hook up a fax phone into the loop and I'm not sure how to hook up.My second problem is,,,everytime I start up my computer whether I'm online or off the application svchost asks my firewall for several approvals to connect to the internet.I'm concerned that it's some kind of spyware or rootkit.Thanks,,rickconstantin@hotmail.com,or kingskidministries@hotmail.com
  • 36 Answers
Hello kingskidrick,
If you want to hook up a fax phone into the loop, first thing you have to do is get an ADSL filter from your ISP or wherever you think it is available. Make a parallel connection from the telephone cable, connect this filter's input to telephone and the output of the filter ( marked as telephone) should be connected to fax phone.
Thank you.
Posted on May 09, 2008
Can not receive a fax
1. You enable sending and receiving separately. Does the balloon pop
up when the phone rings?
2. Make sure that Windows XP fax is attached
to the correct modem.
3. Sometimes if you have a cable for a wireless
phone attached, the fax software will associate itself with that
modem which is only present when the cellular phone is tethered to
the PC.
Jul 16, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Sending a FAX
The fax is sent through the fax modem in your computer. All this printer does is scan the images for you and send them to your fax software which then dials the modem and sends the fax.
Apr 27, 2010 | Dell 924 All-in-One InkJet Printer
Does computer fax modems work in printers also?
You can use a USB fax modem for this purpose that you want to do .....
Dec 07, 2009 | HP Officejet 5610 All-In-One InkJet...
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
Nov 09, 2008 | HP LaserJet 3050 All-In-One Printer
GET "NO DIAL TONE" ERROR.
I must tell you that this is not a printer issue, since printer does not have inbuilt fax capabilities....Actually you are trying to send fax from the computer using a Data Fax Modem. Printer just used for scanning and printing documents for fax...
1. Please check if your computer have Fax modem.
Look at the back of the system tower, if you see a phone jack port (probably two of them).
2. If yes then , you need to have a telephone cable directly from wall (not the ethernet cable coming from DSL modem), fax works on analog signals which is possible only from telehone line.
If your phone line is working, there is no chance the it will give you error again for NO Dial tone
Nov 07, 2008 | Dell 924 All-in-One InkJet Printer
I have a Lexmark all in one printer, X5270, I cannot send or recieve fax's, so would you tell me what I need to do to fix this, as it is suppsed to do fax's. I have Qwest dsl hooked up and have an...
I have an "all in one" model X2580. I haven't attempted faxing, but I just looked up faxing in my user's manual and it appears we need a modem with fax capability to do this. Before reading the manual, I assumed it was done over the Internet.
Text from manual:
"Make Sure:
The printer is connected to a computer that is equipped with a fax modem.
The computer is connected to a working phone line.
Both the printer and the computer are turned on."
Having Quest DSL should not be a problem. but it won't help you.
If you don't have a fax capable modem in or attached to your computer, is one included in your answering machine that could be attached to your computer? If so, this could help. If not, you probably need to install either an internal or external 56K modem with fax. They are not expensive and if you're lucky, someone might give you one id they're changing their ISP from Dialup to DSL or Cable Modem.
I will ask a Lexmark person I have been in contact with recently, but I don't think this can be done over the Internet.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Installed Lexmark 1240 but when I try to set up fax it says no modem found
Yes, This assumes that you are hooking the printer upto a 56k/Fax modem on the Computer, Which the Printer already has itself, What you will want to do, Is hook a Phone line upto the the Printer in the appropriate slot, and dont worry about setting the Fax feature up on your Computer, Just Worry about the Scanner, printer. For the Fax Feature, Dial the number on the Printer and It should work without Ever touching the Computer
Jul 11, 2008 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
50 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
