I've drived deep cleaning but, my printing is still unclear; some lines are clear, but some are unclear. What can I do??? Ken Serial No.; f8m529172 Model No. 1470D Puschase date: 721. 2003
I put in two new ink tanks and still the problem persists. Some lines are fairly clear; some lines are faded. Any other ideas??
Thanks..
Posted on Mar 18, 2008
    Sergeant:
  • 349 Answers
If cleaning does not help ,the heads have stopped working
usually no amount of cleaning via the software helps, but you might try soaking the heads in really hot water for a while then using a soft brush to wipe them gently,wipe dry ,then try cleaning a couple of times through the software .
however it sounds like you need to replace the ink cartridge.
if i have been helpful please rate my efforts.
good luck
Terry
  • terry Mar 19, 2008
    do an alignment test in the printer software, however
    it may be that your printer has the print head in the printer and not on the ink cartridge,in which case changing the ink will not fix it ,looks like a new printer on the way.
    Terry
White lines on dark photo prints
White lines means some of the print head nozzles maybe blocked.
Try the deep clean print head cycles then do a test print. If this still does not fix the problem then a new print head is required.
Print heads are expensive and if your printer is old then maybe better to put your money towards a new printer.
Oct 18, 2012 | Canon MP560 All-In-One InkJet Printer
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The printing is all patching and the lines are either not printed at all, some are clear and some are just spots of lines. I think the nossles may need cleaning but not sure how to. Any other thoughts?
click start
printers and faxes
right click on your printer then click properties
click maintenance
then deep ink cleaning
repeat deep ink cleaning a few times
of it fails
remove ink cartridges and blot them on a piece of cotton soaked in rubbing alcohol until it runs clean.
Apr 06, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Lines/streaks on paper even after deep cleaning and head alignment
Set the print head on a paper towel to dry, drying time will vary. ... Run a print head alignment and a regular cleaning followed by .... Normally you can clear up minor clogs and streaking by running the cleaning cycle found in .... After all the deep cleaning cycles I suspect I have now clogged ...
www.applefritter.com
Dec 06, 2009 | Canon BubbleJet i560 InkJet Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon mp600 won't print every line
hi! there if streak came to your printed paper,try to go on maintenance menu.doing this left click crontol panel and then click your priter,on printer left click and click properties then click maintenance,on maintenance click clean,make it several time then click pattern test if this acquired quality print,if theres problem try the deep cleaning observe there are much ink to consume in deep cleaning,don,t try to clean your print head w/c not recommend on your manual,otherwise you will damage your printer head,if still streak bring this to your cannon service center to check printer head status,regads and havw a nice day thank's.
Mar 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I am getting white horizontal lines through my color photos when I print them. Is there an adjustment that I need to make in order to eliminate these lines for a clear sharp color photograph?
see owners manual PIXMA MX700 Quick Start Guide pages 85-93,:Nozzle Check
Pattern,Print Head Cleaning,Print Head Deep Cleaning and Aligning The Print Head
Mar 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
