Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
Troubleshooting Well about only a week ! The temp. in BIOS shows about 45-6 deg. for the CPU , the fan speed is about 3000 rpm and the system temp. goes around 33 deg. , after 4-5 hours working the pc.
    Scholar:
  • 178 Answers
What is the brand name of the ram you are using? If you look up on AMD's website, it will tell you what RAM is compatable with your processor and mobo. 45 degrees celcius translates to 113 farenheit. If it is a constant temp that way, it is ok. But just at IDLE speed, means the processor is getting over heated more than likely after opening multiple apps.
Posted on Mar 17, 2008
Error on normal boot up, System Fan has stopped, system will shut down in 5 seconds. Boot to BIOS: CPU Fan Speed 1700+rpm System Fan Speed 0RPM (in red) of course CPU Temp 45c/113f I opened the case,...
HI ker7758 ,
You may need to apply "Thermal paste/grease " to the CPU.
You can watch this video tutorial from Youtube:
http://www.youtube.com/watch?v=o7rPqCvCt0g
There are different types of thermal grease. You don't have to buy the expensive ones. The cheapest on the market should be able to do the job.
Apr 09, 2011 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Intel core 2 quad q8300 EXTREME TEMPS
First off....alwys, always apply a very thin film of thermal grease to the cooler and Proc. This grease is designed to fill in the microscopic grooves and holes in the material. Do not glob it on thick, it doesn't work that way.
Case design has something to do with cooling but you are experiencing higher than normal stock temps, the more fans the better, you want some pushing air in the front and pulling it out the back, a good flow across all the hardware is essential. Installing a good processor cooler may require you to remove the motherboard so you can get to the back of the board to mount the cooler retainer plate, but there are other coolers that do not require this. If it were up to me, I would deffinately take the time and remove the motherboard and do this right. You need to get those temps down. I personally like this one....
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118003
Not too expensive and does a great job for the LGA775 socket.
For cases...I always use HAF932s...they have everything that is needed and are tool less.
May 07, 2010 | Core 2 Quad Processor Q8300 - INTEL -...
Fatal1ty FP-IN9 SLI + Q9400 + BIOS16 = wrong CPU temp + noisy fan
I notice that the solution from myself was posted as a comment. This may prevent some from locating it. I reposted as a solution under a different name. Hopefully it would help those have the similar problem.
In addition to the following solution, you may also set the CPU core voltage to your CPU specification. My Q9400 VCore specification is 0.85~1.3625V. The BIOS auto setting sets it at 1.1625V. I just manually set it to 1.3625. CPUZ shows that C1E and stepping will lower it as necessary. It should provide the CPU more juice when it needs it, while keeps it cool when it is idle.
Ok, this is myself (Recnelis). I may find the solution for this problem. The trick is to use the beta BIOS 18 and increase the "CPU VTT Voltage" in the BIOS "SoftMenu Setup".
The beta BIOS 18 could be found here:
http://forums.hexus.net/abit-care-hexus/149415-bios-updates-intel-e0-stepping.html
To make the long story short, BIOS 16 is relatively stable for Q9400 but could not recognize the CPU correctly. BIOS 18 (beta) can recognize the CPU correctly but is very unstable - random application crashes, blue screen, freeze, etc.
Here is some "history" about the issue. Fatal1ty FP-in9 SLI uses nVidia 650i SLI. If you google "nVidia 650i 45nm quad core", you will find a lot of people has the similar issue. Many websites suggest that it is because of the difference between the release version of the Intel 45nm quad core and the one sent to nVidia for testing (due to that nVidia turned off Intel's request for acquiring its SLI technology according to some rumors). Some forums suggest voltage is among those differences.
In the BIOS, you may notice that the voltage settings in the "SoftMenu Setup" are different from the actual voltages in the "PC Health Status". In my case, the actual voltages are similar but lower than the settings. One exception is the "CPU VTT Voltage". The BIOS automatically set it at 1.2V, while the actual voltage in the "PC Health Status" shows it is only a little above 1.0V. That is more than 16% drop. 1.0V is too low to keep the system stable. Guys in o/c world usualy increase the "CPU VTT Voltage" up to 1.5V to keep the system stable. Since I'm not o/c'ing my system, I do not go that far. For my particular case, when I set it to 1.31V in the "SoftMenu Setup", the actual voltage in the "PC Health Status" is 1.2V, which is what the auto setting trys to do. For your system, you may want to increase the setting one notch at a time to safely increase the actual voltage reading.
Before this tweak, my system cannot even run more than 30 minutes under BIOS 18. After this small tweak (under BIOS 18), my system becomes a whole lot more stable (no crash so far after a few days of using). It passed RealTemp torture test (using Prim95) many many times without a single hiccup. I tried to post this at least one week after the system runs in stable status; but I think some of you may still be searching for the solution.
More good news for those who want to keep the Fatal1ty IN-FP9 SLI/Q9400 for a while: I even installed Windows 7 RC (build 7100) with the new nVidia Windows 7 mobo driver and graphic driver. Everything is running smoothly so far.
Good luck to your tweaking.
Recnelis
Apr 02, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Fan overspeeding / usb ports not working
I'm glad that fixed it!
(Posted as a solution so that you can rate the response.)
AMDFan, update to the most recent BIOS and that should fix the problem. It fixed death88scyth's issue, I see no reason as to why it won't fix it for you.
Mar 25, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
Jan 07, 2009 | MSI K8MM3-V Motherboard
Fan on
The CPU fan on the GX280 is a variable speed fan. It only runs as fast as necessary to keep the CPU cool. But the fan also has an rpm sensor built in that regulates it at 3000 rpm. If the sensor is going bad, it senses its running slower than 3000 rpm when its actually running faster and continues to speed up until its wide open. Thus the 'jet engine' sound. Replace the fan and that should do it. If by chance it doesn't, it gets more serious and likely a motherboard problem.
Aug 26, 2008 | Computers & Internet
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Troubleshooting
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Mar 17, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Troubleshooting
No, that's definately not the problem. The airflow seems to be adequate and the temp reading is effecient enough. Ideally, te the idle temperature of any AMD processor should not exceed 30 deg celcius. Look in the bios and make sure your speed is set for clocking to match the ram. Other than that, instead of hardware, I'd look into software config. IE, spyware/adware, Viruses. Beyond that, I will need system specifics in order to help further.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
75 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
