Question about Olympus Camedia C-50 Zoom Digital Camera
Olympus C-50 zoom
Based on your post, my camera probably needs the lens assembly replaced. The lens sometimes will not extend when the cover is slid open. It does rattle when I shake it gently.Is the repair something I could do myself? Do you have any idea what the repair would cost? Would it be better to just replace the camera? I bought it in September 2003. I appreciate any advice you can give.
    Problem Solver:
  • 5 Answers
I have designed and produce on a limited basis a new slide/nut plate for the c-50 that is easy to install using existing screw. Just slide the old nutplate outand slide the new one in and attach screws solves the problem of the sliding door and the off/on switch behind the door ,I sell it for 25.00 +3.00 shipping
John Richardson jarg1@gwi.net
Posted on Apr 19, 2008
I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus SP-350 Digital Camera
Zoom Error message
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 23, 2009 | Olympus SP-550 UZ Digital Camera
Canon Powershot S50 -lens extends and then retracts
There is a common problem with the A series Powershots, that the lens assembly jams in the telescoping zoom, or in the digital imaging module, in which the lens assembly has to be replaced. I'm not sure if the S series has these issues. You can check with Canon support to find out.
Aug 08, 2008 | Canon PowerShot S50 Digital Camera
Putting Lens Back on
How far apart are you? I mean it all goes back together in reverse order. If the lens is disassembled, you need to get the outer lens tube back on its tracks in the inner tube. That takes a little working, but it should be doable. You should be able to turn the small gear that is on the lens assembly and be able to extend the zoom lens, itll be tough, but if you cant, then the camera will probably not be able to do it either, look for something off track.
Apr 14, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Olympus C-370 LENS GOES OUT, IN AND SHUTS OFF
It is possible that a flexible circuit connector has loosened. This can be checked by removing the covers, DISCHARGING THE CAPACITOR. (The large, black, cylinder beside the lens.) Remove the black Phillips screws holding the LCD and main circuit board and then carefully lifting the circuit and checking the large connector on the back of the main circuit. BE CAREFUL! It is easy to break the flex. The other, most likely cause is the failure of the Photo Interrupter in the lens. The only solution is to replace the lens and reprogram the camera.
Sep 18, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
C-50 will not turn on (shooting mode)
If it tries to move and fails, then you have a lens problem. Likely a crack (invisible to the naked eye) in the outer barrel. Usually lets the ball bearing fall out of it's groove between the two barrels. Rattles a little if you gently shake the camera. Almost certainly needs the lens assembly replaced. If it doesn't even try, but the rest of the camera operates normally, then I'd guess you're looking at the interconnection(s) between the mainboard and the lens motor(s). Connector pulled apart, cracked mainboard, or something. you say that "Now it will not work at all" If it doesn't even try and the rest of the camera is dead as a doornail, then perhaps the battery connections? Power board? It would help to know the history of the camera. Was it dropped, sat on, or at the beach? Was it working then suddenly stopped? I've worked on a lot of digital cameras. To determine the problem with the zoom, disassemble the camera down to the lens module. Try to isolate the extension-retraction circuit and drive the motor from an external source. Usually you'll find the lens has broken tracking tabs on the main group barrel or retrofocus converter group or the ways or guides have cracked. I recently repaired a Nikon 4100 that responded nicely because the guide elements just snapped back into place. Usually they snap and break off or are already broken off because most are plastic. Some older ones are aluminum and can be bent back into shape but that takes quite a lot of experience. Sometimes there's just a piece of grit in the ways and you can revive it by complete disassembly and cleaning. Otherwise you might be looking on eBay for a parts camera with a good lens or mainboard. Good luck
May 14, 2006 | Olympus Camedia C-50 Zoom Digital Camera
Open cover
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Olympus Camedia C-50 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
