Everytime I turn on my computer whether I'm online or not the application svchost asks for several approvals from my firewall to connect to the internet.Any suggestions?Thanks,,,rickconstantin@hotmail.com
    Problem Solver:
  • 15 Answers
Don't let it access the internet. svchost is a trojan, so do a full system scan with your anti-virus and get rid of it. if you dont have a anti-virus, go to the avg website and download it.
Posted on Mar 17, 2008
How do i open a specific port on my soniwall tz210 firewall router?
Ports are communication channels for computers and networks.
Certain applications that run over or connect to the Internet require the use of certain ports.
Firewalls block the use of many ports because they can be like open doors, which viruses and hackers use to gain control of your computer.
However, if you have an application that needs to use a port that the firewall has blocked, you can go into firewall and open that port.
Following these instructions will allow you to open a port in the Windows Firewall and give you guidance for other firewalls.
Go to the control panel and click on "Windows Firewall."
If you are using another firewall application, open that application from the Programs menu.
If you are running Microsoft Firewall, you will have to work with both applications.
Verify the status of the firewall.
The first pane that comes up is the general tab and it should indicate whether the firewall is on or not. If the Firewall is not on, chose the "on" option and click "OK."
Open the Firewall application.
Go to the "Exceptions" tab and choose "Add Port."
Give the port opening a name.
Type in the port number you want to open, then choose either "TCP" or "UDP."
In most cases you will select TCP.
UDP is used for connectionless networking that doesn't require an initial connection to send information.
Or right click on the "Network Internet Access" in the bottom task bar select open network and sharing then select see full map you will see all available connections
Hope this helps
Oct 03, 2012 | SonicWALL TZ 210 (01SSC8786) Firewall
When i start my Computer after displaying Welcome Screen the Message appears " The Apllication failed to Initialise properly ( 0xc0000017). Click OK to terminate the Application". So Pls send to me a...
Option 1.
Restart the computer in safe mode, and then remove Aventail Connect. To start Windows in safe mode, press F8 during startup, and then select the safe mode option from the extended boot menu.
Option 2.
Add the Svchost.exe executable file to the Aventail Connect exclusion list. The Svchost.exe file is stored in the %Systemroot%\System32 folder. For example, this file may be in the following location:
C:\Windows\System32
Sep 01, 2010 | Computers & Internet
BSNL net connects but after some time svchost.exe error occurs
The problem is with the Windows operating system. Either the OS is infected by a virus or it is corrupt.
The best and effective thing I can suggest you is to reinstall the Operating system on the computer. Please scan your computer once you have reinstalled the OS using a good antivirus.
Hope this helps.
Jan 12, 2010 | Microsoft Windows XP Professional
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
What is the different between xp serrvice pack 1 and 2
A service pack is a collection of all updates released to that point, and often includes new features, as well.
The major enhancements in Windows XP Service Pack 2 include Security Center, Automatic Updates, Windows Firewall, and Internet Explorer.
Security Center is an entirely new feature provided by Windows XP Service Pack 2. The Security Center service runs as a background process in Windows XP and routinely checks the status of the following components:
1. Windows Firewall: Security Center detects whether Windows Firewall is enabled or disabled. Security Center can also detect the presence of some third-party software firewall products.
2. Automatic Updates: Security Center detects the current Automatic Updates setting in Windows XP. If Automatic Updates is turned off or not set to the recommended settings, the Security Center provides appropriate recommendations.
3. Virus Protection: Security Center detects the presence of antivirus software from many third-party organizations. If the information is available, the Security Center service also determines whether the software is up-to-date and whether real-time scanning is turned on.
When Security Center detects an important security condition (such as improper settings), it displays a pop-up notice in the notification area.
Windows XP Service Pack 2 provides several enhancements to the Automatic Updates feature, including the following:
■ The latest version of Automatic Updates offers expanded support for Microsoft products, including Microsoft Office.
■ Previous versions of Automatic Updates could download only critical updates. Now Automatic Updates can download updates in the following categories: security updates, critical updates, update roll-ups, and service packs.
■ Automatic Updates now prioritizes the download of available updates based on the importance and size of the updates. For example, if a large service pack is being downloaded, and a smaller security update is released to address an exploit, that security update will be downloaded more quickly than the service pack.
■ Automatic Updates is now more automated. The need for users to accept End-User License Agreements (EULAs) has been eliminated. Also, the user now has a choice of whether to restart the computer following the installation of updates that might require a restart. Updates that do require a restart can now be consolidated into a single installation so that only one restart is required.
Previous versions of Windows XP include a software-based firewall named Internet Connection Firewall (ICF). After installing Windows XP Service Pack 2, this firewall is replaced by Windows Firewall.
Windows Firewall boasts a number of enhancements, including the following:
1. Windows Firewall is now enabled by default on all network
connections.
2. Windows Firewall provides an interface for configuring global settings that apply to all the connections of the computer.
3. In Windows XP Service Pack 2, Windows Firewall supports a new feature that allows you to keep Windows Firewall enabled and also not allow any exceptions; only solicited traffic is allowed. This new feature is intended to create an even more secure environment when connecting to the Internet in a public location or other unsecured location.
4. In Windows XP Service Pack 2, a startup Windows Firewall policy performs stateful packet filtering during startup, so that the computer can perform basic network tasks (such as contacting
DHCP and DNS servers) and still be protected.
5. In previous versions, you could not apply firewall rules based on Internet Protocol (IP) addresses. In Windows XP Service Pack 2, you can configure Windows Firewall so that firewall rules apply to IP addresses (or IP address ranges), meaning that only traffic from computers with valid IP addresses is allowed through the firewall.
6. In previous versions, you configure permitted traffic by specifying the TCP and UDP ports used by a service or application. In Windows XP Service Pack 2, you can also configure permitted traffic by specifying the file name of the application. When the application runs, Windows firewall monitors the ports on which the application listens and automatically adds them to the list of allowed incoming traffic.
Internet Explorer:
Windows XP Service Pack 2 introduces a number of new security features to Internet Explorer 6. As with the rest of the enhancements introduced with Windows XP Service Pack 2, most of the updates to Internet Explorer are intended to provide better security.
Jul 16, 2009 | Microsoft Windows XP Professional With...
Svchost.exe problem
i think its a virus or a worm problem to get rid of this go to my blog and download quickheal two months full verion scan it will clear your problem
dont forget to turn off system restore before installing and upto completing the complete scan of your pc
bye bye
http://xviruslab.blogspot.com
Feb 28, 2009 | Microsoft Windows XP Professional
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Can't get Xbox Console to see my pc
THE pc OS is by default configured to NOT share files or folders
xbox will only see shared drives/folder on the pc,
if nothing is shared nothing is accessible.
On the pc
mark a folder as shareable and see whether it becomes available to the xbox
Jul 15, 2008 | Microsoft Xbox 360 Console
Computers, modems,printers
Hello kingskidrick,
If you want to hook up a fax phone into the loop, first thing you have to do is get an ADSL filter from your ISP or wherever you think it is available. Make a parallel connection from the telephone cable, connect this filter's input to telephone and the output of the filter ( marked as telephone) should be connected to fax phone.
Thank you.
Mar 17, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
