Question about Apple iPod nano
I can't hear one side
Help me i can't hear one side of my apple ipod.i've tried diff.headsets but it's still the same
Checked the balance is set to equal in the firmware?
Posted on Mar 17, 2008
I've got an iPod 3rd gen and i'm trying to restore it, but is coming up with an error (2003). Can you help?
Hi joshua4god...
"Try this: I found this solution by one of the other experts here,,.
Turn off your ipod, and hold the home button, and plug it into itunes while still holding the home button until the itunes symbol appears with a cable under it.
Itunes should say "ipod found in restore mode".
Restore your ipod to either a backup of that ipod if there is one, or set up a new ipod.
Setting up a new ipod will fix any previous problem.
Jul 27, 2011 | Apple iPod touch
My music folder is deleted from my ipod A1236,i can only load my music and vidios but i cant listen from the headset
You should try another headset. If this doesnt work. Restore your ipod. try multiple headset again. Still no luck, your headset jack is probably broken.
Mar 01, 2011 | Apple iPod nano
Ipod not recognised by computer
Things to do:
- Try connecting the iPod in to different USB ports of the computer.
- Try different USB cable for iPod. If the same problem occur...
- Try connecting your iPod in to diff. computer and see if the computer will recognize the iPod. If connecting it to diff computer gives the same result, then the storage portion of the iPod is no longer working. Send the iPod to Apple Store and see if they could still fix it.
Thank you!
Sep 12, 2010 | Apple iPod nano
My ipod will play a song, but only the music will come through and not the voice
This is rather unusual as it appears that you are playing your music in 'karaoke' mode on your iPod (but you should still slightly hear the vocals).
Try setting another music equalizer mode such as 'POP' or 'ROCK'.
Dec 27, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
Outside speakers won't turn off when I put my headset in.
There is a switch inside the iPod Nano headset female jack that is deactivated by headset the male jack when it is plugged in. The switch deactivates the outside speakers. In your case, the switch is not deactivated so you hear sound from both. Three things may cause the problem that you need to check.
  1. You are using a not compatible headset. Make sure headset used is compatible with the unit.
  2. The headset is not properly inserted. Insert the headset firmly and make sure it sit firmly in.
  3. The switch inside the unit is defective. It may be stuck or broken. Disassemble the unit to check the switch. Insert the headset and make a visual check if it hits the said switch and deactivates it. You may need the help of a person with know-how in electronics.
Oct 30, 2009 | Apple Audio Players & Recorders
Left side of earphone jack won't work. I have tried more than one headset.
Sounds like a bad headphone jack. Contact Apple at 1-800-APL-CARE.
-=/ Daft Tech /=-
Oct 22, 2009 | Apple iPod classic MP3 Player
Song skipping on iPod
maybe they got corrupted try putting them on the music player again or try getting the same songs but diff versions of the file and you could try last to convert the songs to a diff format then put them on the player if its the the same songs on both the players that wont play then its the songs and not the player
Jun 02, 2009 | Apple iPod nano
Ipod wifi button is greyed out unable to access help please!
me too. i have the same problem but what you need to do is go to any apple store and get it replaced it was maybe caused by a liquid spill.
Apr 29, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Apple iPod nano Logo
65 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
