Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Leak its exactly as you described...where should I look for leaks...I can see water on the inside of the bottom tray but every pipe I can see is dry and none of the plastic parts seem to be cracked...Thanks, Tam.
  • 4 Answers
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed.
Posted on Apr 24, 2008
Water leaking out right hand bottom side and the tray underneath is dry. Is there a hole/pipe blocked ?
The drain is lined up with the tray then the heat from frig evaporates it. Use flashlight to see if the drain hose is in lines with tray so it will hold the excess defrosted water. This is a little tricky cause you might not be able to tell untill it is actually dripping so show patience. thanks
Mar 28, 2010 | Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Refridge leaking water inside it...
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
May 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Should be a little drain hole in the bottom rear of the fridge. Use a pipe cleaner or somthing similar cos it,s probably blocked. Quite a common problem.
May 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Inside rhe house unit is leaking water from around the pvc pipe.
cant understand what you are describing. is the drain pipe clear. water coming out end into french drain or pump. if not clear out by mechanical means or by blowing.
Jan 15, 2009 | Ruud Heating & Cooling
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Jul 09, 2008 | Refrigerators
Water Leaks from front door
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
May 29, 2008 | Refrigerators
Water leaking from bottom. what's up?
the best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Jan 16, 2008 | Starbucks Saeco Italia Digital Barista...
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
76 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
