I have a Sanyo flat screen DP 15647 Yesterday morning the set worked fine. Later in the day I turned it back on and got nothing but a black screen. I kept hitting buttons on the remote and finally got sound, but no picture. Kept hitting buttons and finally lost the sound.
  • folzie Apr 07, 2009
    I have nearly the exact same issue. Yesterday morning watched the TV, then last night when I turned it on... Black. No sound, no picture. I thought I had a problem with the remote... nope. Then when I attempted to turn it off it wouldn't turn off. But once I hit the power button it started to give a click noise. Sorta like the sound you would hear if you had a record, that regular click like the needle does when the record is over. The only way to get the power light to turn off is to unplug the TV. I have repeated this 5-6 times. Every thing is exactly the same.
    Turn it in, power light comes on, and nothing else
    Turn it off and power light stays on and not hear click
    Power light will not go off without unplugging TV
    Plug TV back in and power light is off
    Genius:
  • 1,550 Answers
Change the eeprom
Posted on Mar 17, 2008
SOURCE:
My sanyo dp 55441 wont come on
Try unplugging the TV, an hour later, now reset the TV back to Factory Settings. Now, the TV should be working properly now. Try a website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 13, 2013 | Sanyo DP55441 55 in. LCD HDTV
Sanyo hdtv lcd flat screen--no picture and no sound
first just for trying--unplug set for a few minutes and plug it back to see if it resets.
If not someone will have to open set and check voltages on Power board to see if there or not.
There is another issue common if set 1-2 years old but that is the set at first has to be turned on several times to get it on--let me know if you had that one and I will still advise you.
Mar 19, 2012 | Sanyo Televison & Video
I have a Sanyo model# DP 37819 just stopped working. Black screen , no sound and green power light blinks on and off
Tries tv unplug,replug the tv back like an hour later,now the tv is resetting itself back to the factory setting.Now,the tv should be working now.Not,than this problems,the cause is the power supply board have problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbuish power supply board for the replacement.
Oct 28, 2010 | Sanyo DP42746 42 in. Plasma Television
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
My picture went black on my DP 32647 flat screen Sanyo TV
Check the cords on the back of the television to make sure that nothing got unplugged. Check your plugs and if it is plugged into a power strip check to make sure the power strip is on.
Nov 13, 2009 | Sanyo Televison & Video
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
SANYO TV Picture
I just bought a new Sanyo DP19649 and we can watch it for about 15 minutes then the screen goes black but the sou nd stays on. We have to turn it off and turn it back on to get the picture back for another 15 minutes-then it's the same thing all over again. The sleep mode is off and it isn't on automatic shutoff.
Jul 21, 2009 | Sanyo Televison & Video
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Ekse
