Question about Refrigerators
Frige not cooling com not kicking on
Compressor not turning over. I changed starter and capacitor. I ran great for 24 hours and then started humming again
    Scholar:
  • 178 Answers
Sounds like the compressor has gone out. Unless you can find a slightly more powerful starter capacitor that will be compatable. But then again, how long will that last you? My thought is, either have the compressor replaced or buy a new refrigerator. I am sorry for the bad news.
Posted on Mar 18, 2008
SOURCE:
I have a Goodman a/c unit. Fan stopped shut off
replace the motor the bearing has seized up.
Aug 27, 2014 | Heating & Cooling
My GDM-12 is not cooling. when I turn the temp up it make a loud humming sound.
If the humming last 3-5 seconds then makes a faint click sound and stops humming for a minute or two. Then resumes the hum again it may be your compressor locked down. Stuck. Most likely it is just a bad start capacitor not kick starting the compressor. A $6 part.
Mar 07, 2014 | True GDM-12 Refrigerator Commercial
Maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Sep 30, 2012 | Maytag MFF2557HE Bottom Freezer French...
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
I have a Maytag side by side refrigerator when it is very hot and humid days, it stops working. The relay makes the noise every few minutes.It tries to start but then stops. After 24 hours, it will start...
Hi, When changing the relay the capacitor should also be changed... also the motor could be getting hotter on hot days causing longer run times and then the overload kicks out....that should also be changed but some compressors have the overload internally and they cannot be changed... do not know if that is the case for you... anyway the bit of extra heat can easily be the difference between it working or not...try to get more air flow around the compressor by pulling the fridge out from the wall a bit on hot days.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
When the motor comes on, turns the compressor a few turns, bogs down, triggers the breaker switch.
Either the wiring is insuffcient guage for the load or the motor starter capacitor is bad. If it just started doing this and otherwise ran fine before, replace the capacitor and it will most likely fix the issue.
Jul 27, 2010 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Is my compressor must be replace?
The easiest way for you to find out is to bear the expense of buying the start relay/overload assembly mounted to the pins of the compressor, along with the run capacitor. If this starts it and runs with low amps, like 1-3, you're likely safe. Don't buy food for 24 hours. Sometimes the compressor won't seize again for hours afterward if it has been allowed to cool down before replacing relay.
Aug 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Nov 27, 2007 | Refrigerators
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
