Question about Pioneer SD-533HD5 53" Rear Projection HDTV
SD533HD5 Blowing Fuses
I have been replacing the middle board fuses, and it keeps blowing them. Do I have to replace the Power Suppy Board? Can I do it myself?
    Problem Solver:
  • 6 Answers
I had the sample problem. The fuses are in the middle of the board. You need to disconnect all wires carefully so you can put it back. Find the blown fuses and go to Radio Shack and buy replacement fuses with the same ampere . The main cause is the two STK divergent chips mounted on the biggest heatsink. You need to unsolder them CAREFULLY and buy new chips STK 110 or STK 180. I recommend STK180 because it can handle more heat. Search the web for STK 110 or STK180 I will cost about from $20 to $50. After I replace the 2 chips STK180, I never have any problem since. THe performance and the sharpness is much better. Try to buy brand name SANYO etc..
don't buy bargain chip, keep replacing chips you are going to damage the board. Do the job once and enjoy....
Posted on Mar 26, 2008
    Genius:
  • Pioneer Master
  • 1,550 Answers
No lo creo ,ya que el problema puede ser el circuito horizontal checalo o manda la tv a un taller.
Posted on Mar 17, 2008
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
Fuse keeps blowing on my Whynter portable ac
Is your compressors motor capacitor replaceable? I know that on a split system, a dead capacitor (typically a 35uF) can cause increased current draw, to the point of blowing fuses, though I've never had to replace one on a portable unit. I usually replace them with a 30uF capacitor, roughly the size of a "200ml can of softdrink".
Apr 11, 2014 | Whynter ARC-14S ECO-FRIENDLY 14000 BTU...
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
No power, keeps blowing fuses
The power board has a severe short and will need to be replaced you can get a replacement power board from www.tvrepairworld.com and they assist with installation assitance if you need it.
Mar 31, 2012 | Toshiba 37E200U 37 in TV
My zenith plasma 42w46x tv. doesnt show pic. the sound is there but no pic. I opened it up and founf out the the board on the right side of the tv(looking at it from the back) has two fuses, one of them...
Hi:
This is the X-systain board replace this board and your problem will be solved. The part number can be found on a white sticker some where on the board. Get the number and google it or enter it on E-Bay because alot of shops sell these boards when the get units with bad screens. Or try www.shopjimmy.com for a new board.
Mar 10, 2011 | Televison & Video
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
My Philips 42PF5421 tv keeps blowing the fuse. I have tried three in as many days but pop! I am replacing it with 3amp. ANy ideas?
the power board is what is my concern here.
Things to check
1. Buldging Capacitors
The power board is in distress if its poping that many fuses, I would just have you replace the power board.
Your full model number was not displayed is it a 21 D, B or C
you can find the part HERE
thanks and be sure to rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 20, 2010 | Philips 42PF5421 42 in. LCD Television
Keeps blowing fuses interanlly, any ideas why
Hello, the problem of the continuos blowing of fuse internally is as a result of a defected component on the pcb board of the recevier . you can do this by removing the cover of the recevier and check for the power transistor , power capacitor, if is defected with the use of a multimeter, replace for a new one of the same number
May 16, 2010 | Harman Kardon HK 3380 Receiver
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
131 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
