Question about Samsung 710V 17" LCD Monitor
Samsung Monitor I have a samsun monitor and when the screen cuts off it takes about thirty minutes of messing with the source and menu button to get it back on. What is wrong with this thing
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see any icon or image, there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
What's your problem?
First, make sure this isn't coming from your signal source; these items are not listed in any of the functions described in the manual for your monitor.
If disconnecting, changing or turning off your signal source doesn't get rid of the control item display, try resetting the monitor (maybe the display has some extra firmware features not in the documentation):
  1. Press the Menu button on the side of the monitor.
  2. From the On-Screen Display, navigate to the Setup&Reset menu using the arrow buttons, then press the Source/Select button.
  3. Navigate to "Reset" and select it.
This should restore everything to the factory default setting and get the TV/monitor out of whatever mode it's in.
Dec 03, 2011 | Samsung 23IN Led 1920X1080 5M1 PX2370 Dvi...
I have samsun syncmaster 519s 15'' crt monitor, its not properly showing colour, its showing green vertically and horz... and other problem is every 2 or 3 minute after showing black screen if I touch body...
most likely one of the color guns has burned out. this monitor and in fact all CRT monitors are obsolete and only worth 5 to 10 dollars in good condition, Its time to break down and buy a new monitor as it is not worth fixing. sorry to say, but true
Mar 16, 2011 | Samsung 793DF 17" CRT Monitor
Lock on monitor adjustments don't know how to turn off the lock so we can adjust brightness and color
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Dec 24, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Osd main controls locked
*NOTE* This answer was actually found on another source.
The easiest solution to try is to reset the on screen display in the menu. Hold down the Menu button (it is probably marked Ok) for at least a minute. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section. On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
If resetting the OSD doesn't work, then you probably have a physical problem with your Menu button. Sometimes, particularly on older machines, the connections to the circuit board are dirty or failing. Because you have to actually get into the monitor itself, you will probably void any remaining warranty by attempting this fix. If your monitor is still under warranty, contact the manufacturer to see if there is a local repair shop that can help you.
If you want to tackle this issue yourself, grab a screwdriver and take the plunge. Remove the casing on the monitor itself and locate the contact switch for the menu button on the circuit board. Sometimes, just working it with your fingers or a screwdriver is enough to unstick it - you can try to clean off any dust or grime that has accumulated around it to see if that is the cause.
Nov 27, 2010 | Philips 200W6 Monitor
Hhi my screen samsun 906 bw turn on but the picture are blinkin and no clear
Take a look at the cable is correctly connect or try with other monitor in order to determinate problems with your video card
Aug 15, 2010 | Samsung 906BW LCD Monitor
How do I make the page to cover the whole screen?
Cut a larger sheet of paper. Just kidding!
What 'page'. Do you mean Windows desktop? Or an application within Windows?
If the desktop is not filling the screen, the monitor should have an 'auto' setting within its menus.
My Samsung monitor (different model) has both a menu button and an auto button.
If you are referring to an application window (you can see some of the desktop around the outside of your application, just maximise your application.
May 16, 2010 | Samsung SyncMaster 2253LW Monitor
I've just connected my Samsun LCD monitor to a new HP desktop. I had been with a Dell. Part of the horizontal as well as vertical data is off the screen. I can't figure out how to adjust it with the...
you are probably not going to adjust it with the buttons.
You need to go to the video settings in Windows and choose a resolution that fits the screen.
I would be willing to bet that the new screen is not the same aspect ratio as your old one.
You can change resolutions until you find the correct one for your computer and screen.
Jul 21, 2009 | Samsung SyncMaster 970P 19" LCD Monitor
Problem with syncmaster 204bw
Hi there.
unfortunately this is not a driver issue. if possible, test this screen on a different PC/Laptop.
it sounds like a problem with the screen itself - meaning you will have to take it to a service centre, or if its under warrantee - take it to the shop you baught it from.
*** NB note: samsun screens normally carry a guarantee of AT LEAST 3 years, and not only 1 Year.
Jun 17, 2009 | Samsung SyncMaster 204BW LCD Monitor
Control lock
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Jun 09, 2008 | SAMTRON 55V 15" CRT Monitor
MAC screen doesnt fill Samsung Monitor
Often there is an auto correct button on the monitor, if not them press them menu button and navigate to find horizontal size. If neither of those work you might try taking apart the monitor and reseating the video cable to the monitor.
Jun 08, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
61 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
