Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Gallery Model FWT449GF Tub issue
Greetings. I have a Frigidaire Gallery Model FWT449GF Front load washer. The issue I'm having is that, the tub assembly does not remain stable when the machine goes into the spin cycle. What I initially found when I opened it up was that the spring cmae off on the right side allowing the assembly to drop down. I reattached the spring, then ran the machine, but am still getting the out of balanced wobble of the tub assembly. Could the level-shock be bad and causing this issue?
(This model wasn't listed below, so I put in the next best model/brand)
Thanks.
  • JapGirl Jun 14, 2008
    Hi, guys:
    I have the same problem since last week I washed 2 bath mats. This washer, FWT449GF, started a big noise on a spinning (last a few minutes) at the last phase of cycle.
  • 240 Answers
Level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Posted on Apr 23, 2008
What is the height and width of the frigidaire fwt449gf? is there a model the same size to replace it with?
Hello friend, that's a great question!
I have researched your Frigidaire model, FWT499GF, and located the height of your appliance is 36 inches and the width is 26 and 3/4 inches. I hope this information is helpful to you. I did not see a model that would be a replacement in regards to your current washer. You can reach out to the manufacture or manufacture website for any further assistance with locating a new model.
I see that you stated your washer is buzzing and will not agitate. That could be an issue within your motor or control panel I would recommend seeking assistance from a professional to properly diagnose your washer. -Matt
Sep 21, 2014 | Frigidaire FWT449
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
Where is vent fan on fridgidaire gallery disherwasher
Hello - I am happy to assist you. First, I will need your model (and serial number if you have it) to better address the issue at hand. Thank you.
Jan 23, 2013 | Frigidaire Gallery FGBD2451K Full Console...
My 15 month old frigidaire gallery just died totally today without warning. power outlet is ok . any ideas as the warranty is out model #4A11007114..
Change out the defrost control and cold/temp controls.
See a similar schematic at:
http://www.partselect.com/Schematics/Frigidaire/ZLHFL7NU.gif
Jan 16, 2013 | Frigidaire Gallery GLHS66EJ Side by Side...
TUB NOT DRAINING
Hello Maria Fernando - I will be happy to assist you and I understand that you are stating that the tub is not draining, however or you speaking about a dishwasher or washer? May I please have the exact model number of your unit so I can assist you further in pinpointing you the correct information?
Jan 02, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire (gallery series) err problem
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
613 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
