Question about Refrigerators
Ge refrigerator Model# gsh22jstass
I would like to know how to intitate/start the defrost cycle. it has a circuit board. If it had a manual defrost timer it wouldn't be a problem but thats not the case here.
  • Anonymous Mar 15, 2009
    WHERE IS THE TIMER LOCATED
  • 54 Answers
SOURCE: GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Posted on Jul 03, 2008
SOURCE: defrost timer board for mzd2766geq
Defrost control board is in the top of the refrigerator behind the two levers that control the temperature. You have to take off the plastic cover. There are two screws and then you slide to cover to the side to remove. The board is in a white plastic housing.
Posted on Aug 25, 2008
SolutionGuy
  • 331 Answers
SOURCE: Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Posted on Oct 29, 2008
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
The refrigrator tempreture is 56 degree and every time I reset it to 36 it comes out 56 degree. the refrigrator is very warm from inside the freezer is ok. what is the problem?
The best way to determine what has caused a non defrosting GE electronic control model is to first access the control board. Jump terminals line power to defrost, (J4 and J9). An amp probe should be placed on this jumper wire to determine current draw of the defrost circuit. A three amp draw is what is normal for this circuit. This will eliminate checking behind the evaporator cover to determine a defective heater or over temp device (defrost terminator). Note: This test is only to check the defrost circuit. It does not initiate a defrost cycle. If the unit is in any other cycle than defrost, that cycle will continue to operate as well.
Jul 12, 2011 | General Electric Profile PFCS1PJXSS...
My refrigerator side isn't cooling the freezer is fine on my GE Monogram Model zisb42dca
Possible faulty freezer fan motor. Dirty condenser. Faulty control board.
Feb 23, 2011 | GE Refrigerators
Where is the defrost timer located on ge side bty side model gss25jfmdww
Hi, This model has a mother board instead of a defrost timer. If you are having a defrost issue, the first part you want to test is the defrost heaters. If you need instruction on testing the defrost cycle, please let me know so I can assist you further.
Thanks
Vic
Jul 15, 2009 | GE GSS25JFM Side by Side Refrigerator
HOTPOINT FRIDGE - COILS FROSTING UP
as you know your unit is not going through defrost cycle. you need to replace either the control board, defrost heater and or defrost thermostat. ge is known for their defrost heaters going out.
Jun 24, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ice forming on rear of freezer wall
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Test to see if circuit board is okay
From Appliance Aid.com
WHY Force the Arctica to Defrost if it Don�t Want to? Don't bother using the self-diagnostics feature to force a defrost cycle. On some models � those with control knobs - which technically are not Arctica models (Arctica models have plastic liners with touch pads � Standard GE electronic models with metal liners have knobs) servicers would have to invest in parts to build a �test� control panel, complete with touch pads and digital displays, to achieve this (self-diagnostics) function. Instead, save both time and money by following this helpful Arctica Tip: If a frosted evaporator or a �frost block� is apparent, initiating a defrost cycle may not reveal anything helpful anyway. First, disconnect power and then simply check the resistance across the defrost heater and bimetal circuit at the main board located at the backside. The two associated wires at the main board are almost always BLUE and ORANGE. The heater/bimetal circuit should normally read around 30 ohms roughly. Next, check the evaporator thermister at the main board between thermister input terminals J1-4 (Blue/White) and J1-5 (Blue) to determine that its resistance is greater than 1.2k ohms but not more than 166.8k ohms depending on its ambient temperature. If thermister resistance falls within this range according to temperature (Approximately: 6k ohms at 70�F � 16.3k ohms at 32�F � 51k ohms at 0�F) and the heater/bimetal circuit is diagnosed as good, then replace the main board.
Apr 30, 2009 | Refrigerators
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
PTS25LBM GE Profile Defrost cycle messed up
The GE Profile Refrigerator has circuit boards and sensors are in the freezer that sends a signal to the circuit board to begin and end the defrost cycle. It is very possible the sensor or the circuit board are defective and will need replaced. I will help you solve this if you like. This refrigerator is complex and will take more discussion with you to complete the repair, I am here to help, let me know, Thanks, Sea Breeze
Feb 05, 2009 | GE Refrigerators
Refrigerators Logo
309 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
