Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 32" Triniton TV. Will not turn on.
Red Time Light blinkng four times and then pauses,  and then four times more,  and will not stop.  The set is black...no visdeo or audio....and will not respond to either the remote or the manual power. The cable box is working perfectly...and so are other TV sets in the house.  This appears to be a common problem with SONY Trintrons.  Why doesn't the company respond to this malfunction of design?
  • musicdame Mar 18, 2008
    Thanks so much.....and now let us see if it works!
    Musicdame
  • 4,234 Answers
The four blinks indicate a vertical deflection problem. I would suspect either bad connections on the vertical IC or a defective IC. This IC is a small flat IC with about 9 pins or so and should be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC.
You may also need to replace some capacitors in the circuit, but try the IC first and keep us updated.
Dan
Posted on Mar 17, 2008
When I press button to turn on my Sony 32 Sony Triniton TV, I hear clicking noise as if TV trying to come on, but it does not come on. The red light for Standby keeps flashing, but, TV does not come
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any.
Feb 04, 2015 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony triniton KV- XG29M30 WONT TURN ON
I had a similar problem a few years back . I purchased a new on/off switch from Sony and that seemed to fix things.
Alleluia
Jan 05, 2008 | Televison & Video
32" SOny Triniton
sony blink code try here NESDA.COM
Mar 11, 2007 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
