I'm trying to load Windows XP onto a Maxtor DiamondMax 10 SATA drive.
I have searched the forum and have found that I need to press F6 to
load the SATA drivers from floppy disk during the XP installation.
My problem is that I cannot find the drivers....!
Can anyone help ---please--- and tell me what they look like
(filename.extension) on the T2 Support CD (V2.0) or where I can
download them.
I have searched the Asus site but with no luck.
Also, how do I set up 2 partitions as I have been advised not to use
Fdisk?
Any help will be really appreciated.
Thanks.
Rating: 0%, 0 votes
I have rebuilt the PC and it is working fine. Many thanks for taking
the time to respond and assist.
Many thanks,
Jim
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
This would explain why I can't find the drivers anywhere!
The problem I had was after installing XP and finding the Sata boot
drive was showing as I: instead of C: Also it wouldn't see the 2nd
partition (partitioned with Fdisk) so I thought it was a driver
problem after scouring the sites. Will go back to the drawing
board.
Thanks again.
Jim
Rating: 0%, 0 votes
You don't need drivers. The ICH5 has room for four IDE
and two SATA, and the SATA looks to the OS like PCI based
IDE ports (for Win2K and WinXP). A Microsoft driver should work
fine with this, and you should not need F6. As I understand it.
Downloadable files are here, and I don't see any disk specific
drivers except IAAR (which should be restricted to ICH5R Southbridge
designs - why IAAR is in this directory is anyone's guess).
The manual says ICH5 (non-raid) is on the board, so I
don't see how IAAR is going to help.
http://www.asus.com/support/do wnload/item.aspx?ModelName=T2- P&Type=Al...
The "Onboard IDE Mode" [Enhanced] and
"Enhanced Mode Support" [SATA] is suitable for WinXP, and
allows six drives (four IDE and two SATA) to be connected to
the ICH5. I think that is the default in the BIOS. Even if
you don't have a SATA drive, that is a good setting, as the
other enhanced modes cause IDE disk slowdowns.
So, give the install a try without F6.
Paul
Post a New problem for ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH
Email this problem
Can you Help with these Input Adapters problems?
Fuse F5 burned
