It come up on the screen file missing windowssystemsconfigsystem i dont have setup disk is there away of rebooting it
  • 95 Answers
What is the make and model number of your laptop?
Posted on Mar 17, 2008
SOURCE:
How do i get missing ntldr back
you are missing a key boot file for windows that is special to XP.
Load your installation disk.
restart your computer and when the F2 setup appears in right bottom corner (right after starting) press the F8 key (couple of times) and choose CDrom drive. (if you miss, try CTRL ALT DELETE--to reboot and try again.
(if that does not work, you will have to go into F2 setup and tell the computer to boot from the CDROM--you will find it by looking on each tab for a list of CDROM, Hard Drive, and listing of boot disk priority. Save you change by exiting BIOS set with F10.
At this point you can choose R for repair.
windows should repair itself. Once done, PC will reboot and you should be good.
** if other files are suddenly missing or other weird things, I would recommend a new install of windows. You should have up to date files for antivirus and malware.
Jul 14, 2014 | Dell Latitude D 600/610
Dell inspiron mini screen says "bootmgr is missing
You need to reboot the computer using the disk you made from Windows Backup and Restore. Watch your boot screen and look for "boot opions or boot order (words to that effect).
If always super important to create a Windows Startup Disk/Repair disk as soon as you power on your computer and go through the initial setup.
The next most important task is to create recovery disks. The ultimate task for any laptop or desktop computer is to create a system image backup onto an External Hard Drive. Why? Whenever you get infected or experience a major problem you are copy the system image back to your main drive and everything is in the state it was when you made the backup.
Files should be backed up on regular basis and having an External Hard dDrive always plugged into a USB port makes this a very simple task.
Apr 15, 2013 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Sep 10, 2009 | Computers & Internet
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Computer crashed?
Ouch, sorry to hear that, your os is corrupt, could be one of many reasons including a virus, or just a corrupt HD. Get the OS disk that came with your computer and reboot, make sure to boot the DVD/CD not the HD, start the install process, you will eventually get to point where you can select to do a repair, choose that and see if it will recover, if it does you shouldnt lose anythig, but you will need to reload some drivers and an update.
Also read through the info in this link.
Apr 03, 2009 | E-Machines eMachines Desktop PC
Missing Operating System
Hi!
Dont worrie M8, all files can be saved if the disk is ok
I suggest you run the installation again, but when it comes to reinstall or repaire you select "REPAIRE", then the os will try to repair your system and not reinstall it, that will keep all things on the disk. If that dosent work you have to remove the disk, connect it to another pc/laptop and move the files she dont want to loose. Then put the disk back and reinstall it from the begining.
If you dont know how to connect it to another pc or have the needed cables to do it, i sugest you take the disk to a pc-repaire shop and ask them to help you save the files. They will copy all the files you want and store them on a cd/dvd/memostick. They can even tace a copy of the whole disk if you want.
Good luck
Nic
Mar 17, 2009 | Dell Inspiron 6400 Notebook
Please help me
can't boot from CD There will be an option in the BIOS menu called "BIOS setup" or similar. ..... yes, hit f10. Save and reboot. Still goes to the screen that says :windows
Click on the link above, follow instructions/should get ya back on line........Please dont for get to Vote. Thank You.
Dec 15, 2007 | Acer TravelMate 4150LCi Notebook
Please any body i need help
Click on the link above and follow instructions,Should get ya back on line/ Please dont for get to Vote, Thank You.
Open Questions:
Computers & Internet Logo
20 people viewed this question
Ekse
Alun Cox
