My LG Fuzzy Logic WF-1011STP motion plate at the bottom of the machine keeps coming loose. I have taken off the cover and tightened the screw, it works for a while but when the machine goes into the spin cycle the whole rotating plate comes loose again. The thread still seems to be fine, what am I doing wrong?
I had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
rotating plate roatates for a second and stops
I have an LG WF-T1330TP and had the same experience with the motion bottom plate. Thanks to the response from Luisa because it assist me to fix mine.I will certainly buy the thread loctite to properly fix it.
hi were do you put thread in as the plate has just lifted from that shaft so how do i fix that or tighten it
My wash plate shaft is broken! The plate was loose, so with further investigation found the shaft has threads insde is split open and the bolt os still inside the ca area on the washplate! Wonder what I need to fix this?
