I have an HP dv6000 laptop. It suffered a fall and cracked the screen. So, I bought another one, same model and I'm about to swap hard drives.... Is there anything that i should know before I do it? Any unforeseen dangers that i should be made aware of? Outside of the unknown...
  • 112 Answers
Click on the following link.
http://www.irisvista.com/
A good guide to laptop repairs.
Let me know if this is helpful.
Posted on Mar 17, 2008
  • 807 Answers
Just be careful of body static when touching things like the circuit board or the chips. It can just burn them out.
Ground yourself first by touching the metal pipes in the house. Try not to where plastic sole shoes on a nylon carpet.
Dissconnect the battery and power adapter/charger before starting.
SOURCE:
HP DV6000 Motherbord Replacement
I'm sorry but this is not a warez site...We can't give out activation keys or access codes or tell you how to get pirated software to work.
Sep 04, 2012 | HP Pavilion dv6000 Motherboard
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Swap a hard drives on two exactly same laptops?
Yes, swapping the drives would not result in any data loss.
Please proceed with swapping of hard drives.
Jun 03, 2010 | Computers & Internet
Computer does not boot up
Sounds like the computer cannot find your hard drive and is looking for other means to boot the machine. It first is looking for a network hard drive, then it is looking at the DVD. When that fails it is asking you to check the computer for hardware errors. Check to make sure the hard drive is seated in it's compartment. The DV6000 has an adapter that fits on the end of its SATA drive and sometimes that adapter can wiggle loose from the contacts. Just take the hard drive out and then re-seat it to the connector. In most cases it is either a loose connection or the hard drive has suffered a failure.
May 19, 2010 | HP Pavilion dv6000z Notebook
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
2003 model, HP iPAQ 2210 PDA. Broken screen.
A replacement screen will cost $150+. You might want to get something on Ebay, like the same model with a bad power supply, or bad hard drive, and just swap out the screen. The flat ribbon cables are critical in their placement into their sockets. Make sure the ribbons are well seated, before closing the clamps.
Sep 06, 2009 | HP Computers & Internet
HP pavilion laptop will not boot windows...IDE device not found
You usually get that message when the hard drive has crashed.
Try removing the hard drive from the unit, then reseat it back into place.
Hopefully it was just dislodged a little bit.
Let me know what happens.
Mar 02, 2009 | HP Pavilion zd8000 Notebook
Hp pavillion dv6000 battery problem
Check this site. You may fall into the category of known issues with this model. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=c01087277#c01087277_identify
If you fall into this category, they pay for fixing your laptop. It doesn't have to be under warranty.
Feb 27, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}
Oct 16, 2019 | AVG Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
