Question about Toshiba 36AF41 36" TV
Is 36af41 front ir access
Is there a way to access the ir circuit from the front of the unit; while in place; without having to relocate to a bench and remove the entire case.
    Genius:
  • 1,694 Answers
No,there is only one way....remove the back and pull the
chassis....IR circuit is up front,edge of chassis.......T.
Posted on Mar 18, 2008
Canon photocopy machine model ir 6055 system error 000302-0001
Title
Error in paper front shading
Remedy
  1. Connector disconnection/open circuit of the Scanner Unit (Reader).
  2. Connector disconnection/open circuit of the Reader Controller PCB (PCB1).
  3. Failure of the Scanner Unit (Reader).
  4. Failure of the Reader Controller PCB (PCB1).
Description
Error in shading RAM access, or the shading value is either below or higher than the reference level.
Aug 11, 2016 | Canon Office Equipment & Supplies
How do I open it up to look for a blown fuse to circuit breaker?
When you remove the front control panel you will see the two fuses in the next internal section. Below are instructions for removing control panel:
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Dec 16, 2012 | Samsung SMH8165W Microwave Oven
Gaggia Platinum Swing Brew group will not relocate into position. I have checked all the alignments of the movable parts, but just will not relocate into position. Seems to be a problem with the alignment...
Sometimes if you, turn the machine on without the unit in place it will reset itself, and if on the brew unit the arrow is pointing to the N, then you should be fine, however if the arrow is doing its thing and the gears do not line up then you might have to take it in to get it reprogrammed.
Feb 07, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
How do you level a dishwasher
Most units have screw jacks under the pads which wind down.
As the units are normally under benches you need to adjust them a bit at a time to get it right.
I would assume that the bench is level so I would make sure that the front of the dishwasher is level with the bench then it is a case of playing around with the feet
If you want it spot on you will need to use a spirit level inside the machine so that the baskets are level when the machine is in place
Oct 24, 2009 | Samsung Dishwashers
How do i remove the front seats of a 1998 Pontiac Grand Prix?
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
Sep 01, 2009 | 1998 Pontiac Grand Prix
Need to replace infared eye on 36AF41 Toshiba TV
Yes, the back needs to be removed and the main board slides out to gain access to the IR sensor. Usually, the sensor itself is fine, the connections can get broken. Try resoldering the 3 pins for the sensor first. That alone may resolve the problem.
Keep us posted.
Dan
Jan 30, 2009 | Toshiba 32A41 32" TV
Motorola CDM1250 UHF Radio
Renard, just offhand without see'ing the unit, I'd say that something got sparked wrong in the hookup process. The taletell "puff of smoke" tells me the protection circuit or protector diode got "smoked" in the process. It's more than a fuse now, the protection circuit is blowing the fuse, to stop further damage. I'd say that, at least the protector diode needs changed and to check out for any other damage. Probably need a good tech to visually "check" the unit thruout. Definately needs to have it put on the meters and guages to fix all the damage at one time, something that cannot be done by talking you thru it,,, Mechanic
Feb 08, 2008 | Radio Communications
Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Jan 26, 2008 | Bose (321GS) System
Tv sensor for remote doesnt work
1) solder bad connects on remote sensor mounted to front edge of circuit board or, if necessary
2) Replace sensor Tosh # 23009490 ...........................T.
Jan 08, 2008 | Toshiba 36AF41 36" TV
TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Mar 02, 2007 | Toshiba 34HF81 34" TV
Toshiba 36AF41 36" TV Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
