Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer problem Hi: There is a message in the window on my HP 6110 that says: REMOVE AND CHECK CARTRIDGE. I have done this several times, the message remains. Also, the orange exclamation light is blinking. I've tried everything I can think of, including, but not limited to, removing both cartridges and replacing them, checking for jams, turning the unit off and then on again . . . I would appreciate any help that you may have. Thanks, ginger
  • babbs67 Mar 25, 2008
    same message here - just started a couple of days ago, i have tried turning off , replacing cartridge, push cancel/enter button while plugging in machine, opening back and pushing rollers forward, pushing cartridges all the way to left. This is driving me insane!!!! Please help.
    Sergeant:
    Champion:
  • 210 Answers
have you tries inserting new set of ink cartridge???
try this...
> unplug the power chord.
> remove the rear access door.
> check for any jammed paper. if so remove it.
> clean the rollers using a lint free cloth.
> close the rear access door.
> keep pressing the on button for 20 seconds
> try to copy
if no go
> unplug the power chord while it is turned on
> remove the cartridges
> press and hold the ok and cancel button at the same time.
> while holding them insert the power chord, and wait for few seconds and then release your hands.
> when it asks for the ink cartridge, insert them ad check.
if no go, contact me
thanks and regards
agnel
Posted on Mar 17, 2008
SOURCE:
My hp 6110 has a flashing exclamation mark and says "Remove and check cartridge". I have removed and replaced both cartridges several times but the light stays on and the message still appears. HELP!
Hi
remove cartridges
get a peper towel
and clean metal contacts of cartridges
and the metal contact of cartridge carrier
if the error insist
you need to replace with new ones
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 won't printer get message "remove and check cartridge"
please go ahead and check with a new set off cartridge..
if you are getting the same error then you need unplug the power cable and tap the on button for 10 times then replug that...if still u r getting the same error then press and hold the # 6 and unplug the power cable at the same time..and while pressing those two buttons replug it...
it will reset ur printer....if still u r getting the error..printer needs to be replaced.
Jan 21, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110 - no action from printer...
may be improper ink cartridge. replace the ink cartridge
Aug 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Replace all ink cartridges at the same time.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
231 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
