Question about Philips GoGear HDD6330 MP3 Player
Phillips go gear
My go gear does not turn on anymore. it will just not charge. when i link with pc its not picking it up now and the soft reset does nothin. what can i do?
Thanks,
Dale
  • 8,596 Answers
Make sure the GoGear is disconnected from the computer first. Hold in the volume + button, and continue to hold the volume + button as you reconnect the GoGear to the PC. Once connected, after continuing to hold the volume + button for up to 60 seconds, Windows will go into recovery mode and resuscitate the GoGear.
Posted on Mar 18, 2008
SOURCE:
It wont stay on
Is it turning off with charger connected or without charger?
If it is turning off while charging also, Try doing a soft reset.
  1. Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
  2. Hold until the player shuts down.
  3. Power on the player again by using the Power on/off key.
If this doesn't help, try repair it using Philips device manager program which came with the CD or downloadable from Philips web.
Apr 19, 2014 | Philips GOGEAR SA6045 MP3 Player
Sony E-reader PRS-T2 wo'n't charge
Use a mobilephone charger, not a cable for PC; then update the firmware.
Nov 13, 2013 | Sony Computers & Internet
I got a phillips 2gb go gear. and i charged it on the computer, and when i took out the cors . it froze, how do i get it to turn on...
There is a hard reset on the player if you examine very closely and so if the player has hung up then you can reset so that the processor returns to the stable state.
However if the battery has not charged or there is a hardware fault then it will not reset not restart.
Please check up for warranty in this case with the nearest philips support center.
Aug 27, 2011 | Philips MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
I was charging it and after a while i tried to turn it on, but it doesn't work... It was working fine, but a couple of times i just sttoped working i i was forced to reset it by removing the battery. I...
don't charge battery and let the battery worn out.after that connect it to ac adapter and press reset button.if this doesn't help,try hard reset but you'll lose all data!
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
Mar 28, 2010 | HTC S621 Smartphone (Unlocked) -...
PHILIPS GO GEAR SA3125/97 MP3 VIDEO DRIVERS
it simply means that you haven't added any mp3 or video files... if ya want the drivers go to the link below....
http://rapidshare.com/files/119939557/klmcodec395.rar
after installing this file, go to your philips media converter and add the videos you wanna convert, and convert it... after that jus copy the converted video files to the "videos" folder in your player....
if you have added any files and still your player doesn't detect it, then make sure you've copied it to the right folder... also check if those files are compatible with your player... sa3125/97 supports mp3, wma, n smv media files... n jpeg images...
Jun 24, 2008 | Philips GoGear SA3125/37 MP3 Player
Phillips GoGear SA5125/37 wont power up
The freezing at 87% suggests hardware malfunction, but you can try all of the "soft" fixes to be sure -
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jun 11, 2008 | Audio Players & Recorders
Wont connect
Try using Windows Media Player (version 11 should be fine) to sync music files to it. Using drag-and-drop to the device folder only sometimes works (and usually doesn't).
May 31, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
