Question about Gateway FPD2275W LCD Monitor
GNR F173 172 monitor faulty
When turned on the monitor displays the Desktop OK, sometime slight flaring on the deastop icons.
Open an application up, explorer or task manager for example and the area of the screen covered by the application is full of lines but the desktop is still OK. After 5 to 10 minutes the monitor rights itself.
An internet reapair site says this is reapirable withing their standard price so I guess it's a simple component change. Do you know what may need changing? I'm capable of making the change if I know what it is.
Regards
J Milnes
  • 151 Answers
I think this is the problem of blanking section change the horizantal and vertical blanking transistors.placed near eht.normaly 700 in series and connected with vertical output ic.if they are ok then change vertical output ic.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 17, 2008
GNR TS902W monitor start up problems
GNR TS902 19 inch flat screen computer monitor with 3x4 aspect ratio
Difficult starting or completely dead:- (This is a 'Stock Fault' with these otherwise excellent monitors)
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 VoltDC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V VoltDC Wkg and C819 680 MFD 16 VoltDC Wkg are faulty.
Jul 08, 2014 | GNR 19M1 19" LCD Monitor
Acer as3810t no display
OK, best thing to do is test the external video port with a desktop monitor. The laptop will have a Fn key (function) commonly blue in color. The display icon in conjunction with the Fn key will switch between the 2 displays. Common issues with laptop displays is the back light inside the LCD display of the laptop. Power on laptop in a dark room and sometimes you can see the display, just slightly.
If you can see it, replay or have somebody replay the back light in the display. Was This Helpful? Yes OR No *Please vote yes if this helped you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 07, 2014 | Computers & Internet
Auto shut off of monitor
Instructions for Windows XP
  1. Go to your desktop. Remember to minimize all applications or show only your desktop by pressing the "Win Key + D" combination on your keyboard.
  2. Right-click on your desktop.
  3. Choose the "Properties" option.
  4. Switch to the "Screen Saver" tab.
  5. Click on the "Power" button, and switch to the "Power Schemas" tab.
  6. The default is the "Home/Office" schema. Leave it like this.
  7. In the "Turn Off Monitor" dropdown, choose the desired time and click the "OK" button.
Instructions for Windows Vista and Windows
  3. Choose "Personalize."
  4. Click on the "Screen Saver" icon.
  5. Click on the "Change power settings" link.
  6. Click on "Choose when to turn off the display" in the left pane.
  7. In the "Turn off the display" dropdown, choose the desired time and click the "Save changes" button.
  8. Close the window.
Oct 18, 2013 | HP Pavilion Computers & Internet
I have a number of gnr ts902 monitors which don,t come back on when I reboot the computer until I remove the power from the monitor and reapply it. then the monitor works ok
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 Volt DC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V Volt DC Wkg and C819 680 MFD 16 Volt DC Wkg are faulty.
Good luck
Jul 06, 2011 | Computers & Internet
So I hooked this moniter up to my hp and all I get is two blinking lights
One monitor serves as the primary monitor, and this monitor displays the Logon dialog box when you start your computer. In addition, most programs will display windows on the primary monitor when you initially open them. You can select different screen resolutions and different color quality settings for each monitor. Multiple monitors can be connected to individual video adapters or to a single video adapter that supports multiple outputs. To configure the arrangement of multiple monitors:
  1. Click Start, and then click Control Panel.
  2. Click Appearance and Themes, and then click Display.
  3. On the Settings tab, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  4. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
NOTE: The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Change Primary Monitor
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to designate as the primary monitor.
  2. Click to select the Use this device as the primary monitor check box. Note that this check box is unavailable when you select the monitor icon that is currently set as your primary monitor.
View Same Desktop in Multiple Monitors
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to use in addition to your primary monitor.
  2. Click to select the Extend my Windows desktop onto this monitor check box. After you enable this feature, you can drag items across your screen onto alternate monitors. Or, you can resize a window to stretch it across more than one monitor.
Move Items Between Monitors
  1. On the Settings tab of the Display Properties dialog box, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  2. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply.
  3. Drag an item on your desktop across your screen until it appears on the alternate monitor. Or, you can resize a window to stretch it across more than one monitor.
Using DualviewOn many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor that is attached to the first video out port. Once you attach the second monitor and turn on your computer, use the Display tool in Control Panel to configure your settings, just as you do with multiple monitors. You can use Dualview with docked or undocked portable computers.
Mar 08, 2010 | HP A4331D 20" CRT Monitor
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
How I do disable extended desktop
Windows vista :
Right click on your desktop > Personalize > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
Windows XP :
Right click on your desktop > Properties > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
That should fix it
Oct 30, 2008 | Computers & Internet
Monitor gnr ts 700 driver
GNR Corp Ltd. (UK) Support Q, How do I install/reinstall my GNR monitor drivers? A, Check the link on the GNR website: wwwgnrintl.com. Q, Where can I find the latest drives for my GNR ...
www.amtiva.com/client/gnruk/support/faq.html
Oct 06, 2008 | Computers & Internet
Connecting 2 monitor and tv
Multiple monitors overview On many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor attached to the first video out port.
Once you attach the second monitor and turn on your computer, use Display in Control Panel to configure your settings, just as you do with multiple monitors. Dualview can be used with docked or undocked portable computers.
Arrange multiple monitors To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Jul 29, 2008 | Computers & Internet
GIGABYTE X1300PRO GRAPHIC CARD
  1. Open Display in Control Panel.
Notes
Nov 19, 2007 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
236 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
