Question about Dell PowerEdge 1800 Server
Dell server poweredge 1800 frequently shutdown
Every day we found the dell 1800 server is shutting down ,
we use it as an application server for a website
  • Anonymous Mar 31, 2008
    i got the same server here at the company the main reason i think should be overheatin due to this fuckers at the office keep shuting down the AC so every day when u walk in the room it feels like a sauna i've done the dell dset report 3 times and there always the temperature is above normal, even we got a ibm server next to the dell server and the first month we had to change the motherboard i dont know it if was overheatin or it came defective from the factory
    my sujestion DONT TURN OFF THE AC clean all the fans and only use the nescesary software u gonna need
  • Chris Patteson Apr 22, 2008
    We are seeing the same problem. Patched the SCSI as it appears that it was out of date the LSI patch will not take.
    Running RAID 1 on the Perc SCSI on the system. The Orange light is blinking on the box, but when I watch on reboot no errors. (and the lights on the drives are fine)
    There is one interesting message about NVRAM etc and says flushing cache on SCSI (is that an error?).
    I have built out at least 20 server installs. Have never hit this kind of "ghost in the machine issue"
    An occasional BSOD on Sever 2003 that tells little more than a hex dump (which I am not skilled enough to read).
    Problem Solver:
  • 9 Answers
Go to
select your product
find dell server updates dvd
update everything on your server.
Install latest open manage server administrator should be 5.5 now.
clear hardware logs and monitor system again.
Try to use UPS
Posted on Jan 10, 2009
The coming out error message " unexpected shutdown"
i hope that it will help u
thanks a lot
Posted on Mar 18, 2008
    Problem Solver:
  • 7 Answers
Is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Posted on Mar 17, 2008
Dell server shutdown
Try using OMSA, which is Dell's Server Administrator. Specifically for hardware and errors.
https://servername:1311 You require a local admin or domain account to login.
May 20, 2013 | Dell PowerEdge R200 Server
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Dell Poweredge 840 shutdown automatically
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | Dell PowerEdge 840 (becwmk1_2) Server
Poweredge 1800 shuts itself down several times a day.
A server shuts itself
1 if some hardware problem is there. so check any yellow/organge colour led is glowing in the server which indicates hardware failure.if it under AMC then get it checked with vendor.
2 when there is some problem with the OS.
2 when the surrounding temp of the server is very high.
Jan 25, 2011 | Dell PowerEdge 1800 Server
Are there any programs available for maintenance on a Dell Poweredge 1800 (registry cleaner, etc)?
Ccleaner is a good application to use on servers and pc's alike. it is free and can be downloaded from it has a registry scanner that will find and repair registry errors. I work for a hospital IT company and we use it all the time.
Dec 21, 2010 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Dell PE1800 psu wont swith off...Computer powers down but psu fan continues to run. Have to pull the power plug to shut it down.
Sounds like the PSU is overheating. Some PSU's are designed to keep the fan running to cool it down even after system shut down. I would let the fan run after shutdown to see how long it takes to shut itself off. If there are no environmental issues tat are causing overheating you might want to consider replacing the PSU.
Sep 13, 2009 | Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Poweredge 1800 trouble shooting support
Upgrade your bios or set temperture high on the management software
Jun 16, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
1,068 people viewed this question
Alun Cox
