Question about Refrigerators
Shut-off arm won't fall in Maytag ice maker
This is a Maytag side-by-side. The tag on the front says, "Maytag Plus". We bought it 5 years ago.
The ice maker works but when it dispenses ice and lifts the shut-off arm, the arm stays up. It doesn't fall back down. When I reach and and move the arm, I can move it to any position, but it sticks there.
Ever seen this before? Any suggestions?
This seems like a minor issue that should be easy to solve. I hate to call a tech and pay the $70 minimum for a such a simple thing.
Thanks.
  • 4 more comments
  • cheri5858 May 31, 2008
    We have a similar problem. Our Frigidaire ice maker arm sticks in the up position and doesn't release the ice. Any help would be appreciated.
  • lturner57 Jun 11, 2008
    I have a Kenmore and the arm does the same thing. Once I tap it down it releases ice cubes. Once new ice is formed I have to again manually tap the arm down. What do I do????
  • Anonymous Jul 19, 2008
    I have a Kenmore with the same issue. I was hoping to find the answer here.
  • Anonymous Sep 04, 2008
    Kenmore ice maker in top freezer section of refrigerator - shut off arm locks in up position after cycle of ice drops.
  • Anonymous Sep 21, 2008
    I have a whirlpool and it has started doing the same thing. In my internet search, I just saw a suggestion to take the ice maker out and let it sit at room temp for a day or so. I am going to give that a try.
    Another suggestion I saw out there was that there is a spring that might need replaced.
    I googled "ice maker problem with shut off arm"
  • manatee_jax Apr 02, 2009
    We are having the same problem with our LG French door fridge bought in 2007. This ice maker is in the door. Have tried the shut/off-leave off-turn back on (don't forget to remove any ice if it's in the door). Sometimes that works, sometimes it doesn't. It's never permanently fixed. I'm afraid we are going to break the arm sometimes. Still have not located a permanent fix.
  • 87 Answers
SOURCE: Maytag refridgerator leaking water down the front
It sounds as though you may have a 'dodgey' water solenoid valve which is allowing a constant flow through the valve. When the water enters the cabinet it goes into a double solenoid valve which splits the suply to the ice machine and the water supply. This valve can get limescale build up preventing it from closing properly. This is really the only control you have over the water supply. The solution I would suggest is replacing this valve. However I would suggest getting a professional to do this as you would then get some sort of guarantee on the work carried out. This valve is located on the rear of the cabinet normally on the RHS. Hope this is of some help.
Posted on Sep 11, 2007
SOURCE: ice and water dispenser for Maytag H20 not working
Here's what you do...........
call maytag 1-888 4maytag, Tell them your problem... they will ask for your model # and serial #, tell them you know what the problem is its that you need a new high voltage board and you have gone on-line and you know that it is the problem. they will send you a high voltage board and you call them back and they will send a repair man all for free. I called 12-11-07 and am starting a 3 to 4 business day count down to see how they do. Meanwhile im listening to this hunk o #$#@ clatter and have lost the use of 2 rooms due to the anoying noise.
Posted on Dec 11, 2007
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
  • 2841 Answers
SOURCE: The ice-maker shutoff arm in
The arm should move to the up position just before dumping the next batch of ice thus preventing ice from piling up on the arm. After the ice is dumped the arm goes back down. Once the ice bin if full the arm cannot go down and this shuts the production of ice off. The arm will be supported on one or both ends. Make sure it is securely in place. Pull the arm to the up (off) position and then come back in a couple of hours to make sure no ice is being made. If it still is making ice then the control module or shutoff switch may be bad. There are 2 types of ice makers. One in which all the parts can be replaced individually and one in which there are bunched together in a control module. If there is a knob, pull that off first. Module units have holes in the face plate marked with a letter and do not have a separate shutoff switch. Component units have no holes and will have exposed gears. If you see no holes pry off the face plate. Now click this link on the procedure to test the shutoff switch on a component unit. http://www.acmehowto.com/howto/appliance/icemaker/check/shutoffswitch.php
Posted on Jul 19, 2010
Testimonial: "We found the problem was caused by the frig being unlevel, so we didn't need to use this advice, but I think the advice was very clear and thorough."
Turning off the ice maker on my may tag refrigerator freezer
Hello, Suzanne -
Most ice makers in refrigerator / freezers have a heavy metal wire "arm" which activates and deactivates the ice making process. When the "arm" is in the down position, ice is made.
With most refrigerator / freezer ice makers, the "arm" can be set in the up position, so that the ice making process is stopped.
See information here:
http://www.acmehowto.com/howto/appliance/icemaker/check/shutoffarm.php
Best wishes.
May 08, 2018 | Maytag Refrigerators
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker flap don't shut all the time
The flap may be getting stuck on the ice guide which is mounted on the arm you push in th dispense the ice . ( pt # 2180224 ) . Try pushing the arm in and look to see if the flap is catching on the clear plastic piece .
Aug 24, 2009 | Whirlpool Freezers
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator is making a loid noise
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
Mar 10, 2008 | Refrigerators
Refrigerators Logo
1,277 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
