Question about Dryers
Dryer spins but no hot air comes out
The dryer spins the clothes but after running for 60 min. or so, the clothes are still wet and cold.
  • sthomas36 Oct 02, 2008
    I put the clothes in but they don't dry. I canged the fuse that was blown but still nothing. I'm at a lose on what to do next.
  • Anonymous Dec 11, 2008
    dryer turns but no heat, help
Where are the fuses
Posted on Apr 21, 2008
  • 20 Answers
Check the fuses.one runs and other heats it.might be a wire burnt off in the back or on the motor
Posted on Mar 24, 2008
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
I have a gas dryer and cloths come out wet
Does the dryer get hot? If so check dryer vent.
If it is cold check the gas supply. Next open the lower cover and look to see a red glowing from the ignitor when running. It it comes on and no flame then you probably have a bad gas solenoid. If there is no red glow then it is probably the ignitor.
Hope that helps
Dale
Nov 10, 2013 | KitchenAid Clothes Dryer Gas Dryer Ignitor...
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
126 people viewed this question
Top Dryers Experts
Marvin
Marvin
