Question about Motorola Cell Phones
Jawbone 2 won't charge
I have had this less than a year and it won't take charge at all now. I plug it into the wall, and magnetically hook the jawbone to the charger, but no red light will come on at all now. I use my jawbone for my job, and now what am i gonna do?
I'bve got the same problem with using the apapter plugged into the wall but the headset still charges if the apapter is not used and the usb connector is plugged into my PC.
Try it.
Posted on Apr 24, 2010
  • 2 more comments
  • pete1899 Apr 24, 2010
    Update on this is that the apapter now seems to be working. It comes in two parts where the prongs can be slid off the main part of the adapter if you press in the catch with a pen or something similar. All I did then was to re-attach it and it's come back to life.
  • noesnana Mar 02, 2011
    I have the same problem and tried what Pete said. It will charge on the usb port of my computer but not when plugged into the wall. I ordered a new charger awhile back and it would not keep the headset attached by the magnet. Found the original but like I said, only charges if plugged into pc. go figure.
  • Austin Smith
    Austin Smith Nov 14, 2012
    mine wont charge on pc or wall
  • John Purdin
    John Purdin Jul 16, 2015
    same here Austin I have up24 and I sent in a ticket just now Ive had mine less than 7 months 1st time It wont charge no green light showing its charging nothing!
My jawbone doesn't have any light on when it's supposed to be charging
It probably doesnt work just like my tablet my charger doesnt work so i have to take it to best buy. Thanks for my Option.
Jan 07, 2015 | Jawbone JBR03-SM Up Bluetooth Band, Size:...
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
How do i pair my jawbone bluetooth headset to my envy touch?
I found this on another website and it worked for me.
"I was also having a lot of difficulty getting my Jawbone II or "new Jawbone" into pairing mode. I finally ended up carefully removing the outer plastic shield. It popped off without breaking anything and then I was able to easily press BOTH the noise shield button AND the talk button. With the plastic cover OFF, I was able to put my Jawbone into pairing mode on the FIRST TRY!"
Jan 19, 2011 | LG enV Touch VX11000 Cell Phone
My Droid won't discover the Jawbone headset in scan mode. Any ideas?
do you have both units in scan (discover or pairing) mode? both units have to be set to pair for the connection to take place. Make sure the jawbone is fully charged up as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 03, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My motorokr will not find my jawbone 2
I reccomend a motorola bluetooth because most jawbone headsets do not work
Jun 18, 2009 | Samsung SPH-m520 Cell Phone
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Jawbone bluetooth does not charge
My jawbone was not charging at all, but then I looked at the prongs on the charger and I saw that one of them was shorter than the others, so I got a pair of small needle nose pliers and gently pulled on it. It returned to its normal length and I plugged it up. It is now charging normally.
Jawbone should design a better charging system.
Dec 14, 2008 | Cell Phones
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Nov 21, 2007 | Apple iPhone Smartphone
Cell Phones Logo
2,053 people viewed this question
Top Motorola Cell Phones Experts
Damen Wong
Damen Wong
270rexton
270rexton
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
