Home | RCA | DRC247N DVD Player | CODE REGION
RCA DRC247N DVD Player
Problem for RCA DRC247N DVD Player
CODE REGION
By nonameishere on Mar 17, 2008
My dvd player (DRC247N)DOESN'T PLAY REGION 5, hOW DO I CHANGE THE CODE?
Same Problem
Jan 04, 2009
-   can not play a dvd-   Guest
Solution #1
posted on Aug 07, 2008
Not Rated)
jaffa012001
Rank: Guru
Rating: 90%, 455 votes
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Was this helpful?
Yes
No
Popular Solutions for RCA DRC247N DVD Player
Questions and Unsolved Problems for RCA DRC247N DVD Player
Do you recommend RCA DRC247N DVD Player?
Answer
Answer
how do i take off the progressive scan after i enabled it and now my screen is un recognizable. i... (More)
Answer
My dvd player is starting to freeze up while playing a dvd. Is there anything I can do to correct... (More)
Answer
I am unable to play my burnt DVD-R in my RCA player. What can I do?
Answer
i was putting in code for new remote when the screen started flicking vertically and does'nt stop.... (More)
Answer
I have hooked up by DVR using component cables to a Samsung LN32B360 tv and the picture when I view... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA DRC247N DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
