Question about Apple iPhone Smartphone
Connecting Apple Iphone in Windows XP Laptop
I am using GPRS on Apple iphone and am able to brouse through the handset. Now I would like to connect my laptop using apple iphone and surf net on my laptop. Please guide as to how i will be able to do the same.
  • 2 more comments
  • Anonymous Mar 28, 2008
    i cannot connect my iphone to my labtop .What must i do
  • amit2790 Mar 29, 2008
    cant connect GPRS to laptop through my i-phone...wt to do?
  • jamierpuchi Apr 17, 2008
    I need to download from my laptop to my iPhone, I do NOT how, help me please
  • adhie gallia May 21, 2008
    i have my new iphone. i want to download itunes from my laptop to my iphone. But the moment i connect the iphone's dock into the lappy my laptop shuts down having a warning message with blue screen. i dnt know wat to do then
When lappy shutdown with blue screen as u connect your iphone, that means one of the software installed in your laptop is creating problem, the only solution is format your laptop or can say shift your laptop to the factory settings and then download itunes first. This time you;ll find no shutting down of your laptop.
Now when everything is going smoothly load the other softwares in your laptop one by one and connect iphone after every software load, only this way you can find which software is creating problem of shutdown.
VIKAS DEM (094141 81990)
Kota (Rajasthan)
Posted on Aug 14, 2008
SOURCE:
How do i start using iOS 5 in iPhone 4
All you need to do is connect your iphone to iTunes and get the iOS upgraded when it is synchronized.
Update your phone with itunes by connecting it and clicking on the "Check for Update" button while holding down the Option key (Shift on a PC). Select the iOS5 IPSW you just downloaded and confirm.
Sep 13, 2011 | Apple iPhone Smartphone
How can i open my gprs? I have a black iphone and cant open my gprs. dont know the handset model.
why you want to open the gprs! you talk of the network of your sim card! give me the version of iphone
setting+general+about
May 09, 2011 | Apple iPhone 3G
I have photos on my 3g apple iphone I want to share on my laptop how do I download them from my phone to my laptop????
here is a smart way to help you,
Download SetupiPhoneBrowser.1.7.exe
for windows xp
http://code.google.com/p/iphonebrowser/downloads/list
for mac:
http://www.downloadoldversion.com/iphone-explorer-for-mac.html
Run the installer on your Windows XP (May not work well on Vista).
Upgrade your iTunes to 7.7.1 (it works on iTunes 7.7 as well).
Open the iPhoneBrowser and connect your iPhone to the computer via the USB cable. The iPhoneBrowser should detect the iPhone and show the file structure on its screen.You can now drag and drop files to the iPhone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Apple iPhone 3G
I cannot configure the gprs connection of my iphone
Hi, checkout this related GPRS post to lookup the settings you need.
http://www.iphone-tips-tricks.com/2007/11/tip-does-edge-iphone-work-on-gprs.html
May 11, 2009 | Apple iPhone 3G Black Smartphone
IPhone can't charge and can't be detected by PC
Be sure that your Windows PC meets the minimum system requirements to use iTunes and iPhone. This is particularly important if you are connecting iPhone to your computer for the first time. iPhone requires a specific minimum version of iTunes.
Ensure the computer's drivers are up to date
iPhone requires USB 2.0 to function properly. Refer to the documentation for your computer to verify that the USB ports are high-power USB 2.0 ports. Try connecting iPhone to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPhone to your keyboard's USB ports is not recommended.
In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
iPhone requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPhone the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service. If these are not installed, see the Reinstall iTunes section below.
Verify that the driver is installed by connecting iPhone to the computer and following these steps:
  1. On the Start menu, click Run.
  2. In the Open field, type devmgmt.msc and click OK. A list of devices will be displayed.
  3. Scroll down to Universal Serial Bus controllers and click the small plus sign to expand this group. iPhone will be listed as either Apple iPhone or Apple Mobile Device depending on the version of the driver installed.
  4. Right-click Apple iPhone (or Apple Mobile Device) and choose Properties from the shortcut menu.
  5. When the Properties window opens, select the Driver tab.
  6. Click Driver Details to view more information.
Verify that the Apple Mobile Device Service is installed and running using the Services MMC snap-in using these steps:
  2. In the Open field, type services.msc and click OK. A list of devices will be displayed.
  3. View the list In alphabetical order and verify that the "Apple Mobile Device Service" status is "Started."
    1. If the status does not indicate the service is started, right-click Apple Mobile Device Service and choose Startfrom the shortcut menu.
    2. If the service is installed and started, right-click the service and choose Restart from the shortcut menu.
    3. If the driver is installed and the service is installed and started, check the Event Viewer for error messages.
      2. In the Open field, type eventvwr.msc and click OK.
Jan 24, 2009 | Cell Phones
Iphone Q380A
how to activate GPRS and MMS
Sep 04, 2008 | Apple iPhone Smartphone
MY IPHONE Q380_A
how can i connect to the gprs of my iphone Q380_A? I AM A SMART USER
Sep 01, 2008 | Apple iPhone Smartphone
GPRS on iphone
No because the iPhone only has Edge and Wifi capabilities but i have heard GPRS maybe in a future Version.
May 06, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
227 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
