Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1440wh01 everything is working but won't cook no heat
  • Anonymous Mar 21, 2008
    I have an MQS0803W almost 16 years old and all of a sudden no warnings when I turned it on the noise got louder and it goes through the time required but no heat. What should I do?
  • Anonymous May 10, 2009
    No heat no cooking, but everything else works.
  • GE Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Also, since you have a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
3 Suggested Answers
  • 1214 Answers
SOURCE: ge jvm 1653 won't heat
You've got a problem in the microwave circuit, which could be one or more of the following components -
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
I am leaning to the diode, but it would take further investigation to determine for sure. Diodes are cheap, as if the capacitor, and replacing those first would not necessarily be in vain if it turns out to be the transformer or magnetron. And I would be most inclined to say it's the magnetron before I would think transformer.
Reply back what you find or if you have more questions.
Posted on Feb 04, 2009
  • 123 Answers
SOURCE: GE JVM1440WH01 Will not heat, everything else
It could be a number of things, Burnt connections between the magnetron, Capacitor, Diode and transformer, Heater connections loose or burnt, Transformer, Capacitor Diode or Magnetron US. You need to strip it and find out if you are getting about 2000volts to the Mag, Are you getting approx 5volts across the heater terminals?? NOTE that the 2000 Volts can remain in the cap indefinitely and the voltage is LETHAL. IT WILL KILL YOU if you don`t take precautions. Ian
Posted on Aug 06, 2009
Owners manual for a GE Spacemaker over the range microwave model #JVM1440WH01
GE has the manuals for most of their products on their support site: http://www.geappliances.com/ge/service-and-support/literature.htm?icid=GEARsupportflyout-manuals . The direct link to the Owner's Manual for the JVM1440WH01 is currently https://www.myapstore.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40473.pdf . This particular model's support page is https://www.geapplianceparts.com/store/parts/assembly/JVM1440WH01 .
I hope this helps.
Oct 15, 2017 | GE Microwave Ovens
Space maker JVM1440WH01 sounds like it is heating, turntable turns light works, but food does not heat???
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
0'''''''''''''
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
GE microwave will not heat, everything else works, any ideas?
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Sep 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440WH01 Will not heat, everything else works. This unit is 6 years old and just stopped heating. The carosel turns, fans work, the timer counts down and lights come on when you start cooking or open...
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Is not cooking
sounds like the magtron is gone out.
Call GE answer center 1-800-626-2000 ask for tech help. Have you model # off the data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm 1653 won't heat
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
Feb 04, 2009 | GE Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
698 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
