Question about Keurig Ultra B50 1-Cup Coffee Maker
Loud water pump
When the machine is pumping water from the resevoir it makes a loud grinding and vibrating noise. I called Keurig, and they tell me this is normal. Any ideas on how to stop/quiet this noise?
Acorn
  • 3 more comments
  • PDoddy Apr 06, 2008
    Same thing. Brand new, awful grinding/vibrating noise. Exactly what you don't want before you've had that first cup. We've done nothing so far other than this research to see if we were alone here. Considering just returning it, though might try a thin rubber mat base first, just in case.
  • pierre5355 Jun 26, 2008
    Keurig b70 Have the same problem the machine almost moves on the counter from vibration and the noise is very annoying
  • BeckieFaulke Oct 19, 2008
    We have the same problem. Tried placing a rubber mat underneath, and a stack of placemats. Both helped to muffle the sound a bit, but still annoyingly loud.
  • woebegone Nov 11, 2008
    Ditto. Another who owns one had same experience. Personally, it's a deal breaker. Not the sort of ambiance for relaxing with your favorite soothing hot beverage. And the cobalt blue lights - just 'cold'.
  • tonyandbrand Apr 12, 2009
    I love my machine but I HATE the noise! My husband and I work different shifts, so it oftens wakes one of us up. I'm wondering if we should upgrade for a more silent cup in the morning?
3 Suggested Answers
  • 25 Answers
SOURCE: the water pump does not appear to be working
The Keurig machine is either clogged with coffee grounds or the air bladder needs to be replaced. Use the key tool under the tray to clean out machine. If this does not work you can have the machine repaird. I hope this works.
Posted on May 14, 2009
  • 40 Answers
SOURCE: Our Keurig was given to us as a gift. I said...i
scale build-up will cause this too.
Posted on Oct 07, 2010
Why is My cimbali 21 s junior is making a loud noise when turn on
The La Cimbali Junior is a 1 group professional espresso machine. Most are located in restaurants that want to serve a cup or two for customers. You will find few homes with this level of machine. Especially with the proliferation of "Mini Super-Automatics" now offered where the whole been is ground, measured, compacted, and served with exacting amount and some top off with frothed milk!
The JR has several items that will normally buzz or whine when in operation. There are also defined "Clicks" of the group valve when a shot is pulled. I will go through the list of likely components that make loud noises when about to fail.
*** The following is for information only! Call your vendor for service as there are dangerous voltages, high pressure, and scalding stem present in these types of professional machines. ***
* All JR's come with a water pump. Two types; Vibration and Rotary. The vibration makes a buzzing sound (50/60 Hz) which will get loud if there is a blockage. The rotary pump with it's accompanying large motor will also "Clack" if no water is flowing through. Stop immediately as both sounds are an indication of a straining pump. If it suddenly goes quiet then the pump is damaged or hopefully the fuse blew. Call for service.
* The group valve will usually buzz when pulling a shot. But if it's louder than normal then there is a problem with the valve (clogged) or coil (shorted). Call for service.
* If there are loud blasts of steam and a quiet period with another blast in about 10 mins. Then the boiler is over heating (runaway steam). Unplug and call for service.
* If there is constant steam blast from the top, even if it's turned off (But NOT unplugged) the element is shorted to water. Unplug immediately and call for service.
* Popping sounds are normal at start up as the metal boiler expands during initial heating. But not after 10 mins of heating. Especially if you see water/steam coming from parts of the machine you don't expect. Unplug. Call for service.
* Power/Heater contactor will buzz if coil is damaged or contacts burnt. Call for service.
* Final; I do not recommend opening the machine yourself as once you hear a loud noise it's usually too late and the damage is done.
* Parts that needs check/replacement; Vibration or rotary pump, motor, group valve, safety valve, vacuum valve, thermostat/pressure-stat, element, boiler and element gasket, contactor.
Aloha, ukeboy57
Aug 26, 2014 | La Cimbali Junior Casa DT1 Espresso...
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Replace water pump on frigidaire affinity
Plug off the wall. Open the door, keep your thumb at the opening and move the drum towards you and to the back of machine. If you hear some clicking or vibration, your bearings have shot. YouTube makes it easy to change.
Pl click if helped.
Mar 28, 2013 | Frigidaire Washing Machines
Make extremely loud noise when you first turn it on and it heats the water and again after each cup of coffee
This the water pump when is working. It should make loud noise. In extreme case in very loud but after a while it become less loud. If just consider that other smaler models have a smaler pump which is silent pump but they dont have it work always so in you case you a very good coffee result.
Jul 10, 2010 | Keurig B100 Coffee Maker
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
The water pump does not appear to be working
Apr 25, 2009 | Keurig B50 Coffee Maker
I have an old ariete centro caffe espresso machine with a coffee grinder. I filled up the resevoir with water and it seems that the pump is not pumping the water through the machine. My question is does it...
Hi Hi rolo 124,
does the pump make noise? If so, you can try to fill up the hose with water, sometimes it works. If the noise ist first loud then less loud may be that the water cant flow, because the whole maschine is calcified, try to decalcify, best and secure way with tartaric acid. If there is no noise, the pump may be damaged, or there is a fuse blown (mechanical or electric) at the pump.
Good luck
Jens
Dec 05, 2008 | Coffee Makers & Espresso Machines
Keurig Ultra B50 1-Cup Coffee Maker Logo
224 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
