Question about Canon BJC 80 InkJet Printer
Doesn´t print at all
Error flash is on, doesn´t accept any print order. ink cartridges are new
  • Anonymous Mar 22, 2008
    BJC-85 does not print at all. Message on computer says "scanner cartridge detected" Job: Maintenance. Click OK after replacing cartridge" I have the same BCI-11 color & black cartridges as always - both are new. Printer will not clean heads, check nozzles or do anything. Green lite on, no error light. Computer has Windows XP-Pro. Could that be the problem?
    Problem Solver:
  • 18 Answers
The cartridge is defective. Replace with BC-10 high capacity Black, or BC-11e Color.
Posted on Oct 05, 2008
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
Replaced the ink cartridge and it is not printing
Try to check your ink levels. On your computer, go to Start menu > Programs > Lexmark 2500 Series folder > Lexmark Solution Center. If ink levels are substantial for printing, go to the Maintenance tab and select Clean to fix horizontal streaks. It could be due to clogs and dirt in the cartridge nozzles caused by long periods of non-usage.
If the light continues to flash for both cartridges, try to replace both cartridges with different known working cartridges or better yet, replace them with new genuine Lexmark supplies.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
The printer does an Error code 0xc18a0001 Ink failure and the computer doesn't seem to take the printer on I plug it in and out doesn't matter it's just like if I wouldn't plug in any new...
TO clear the error and return the printer to working order you will need to do an ink purge and reset. The problem is caused by air in the ink cartridges. This can happen if you use refilled cartridges or if you let the ink run to low and try to print something. Here is a link to an article that explains what has happened and how to solve the problem.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 23, 2011 | HP Photosmart C7180 All-In-One InkJet...
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Every time i turn my printer on it flashes E, 5... and the alarm button is lit. i installed brand new 40 black and 41 color canon ink cartridges, and the error still isn't fixed
r u sure new cartridge is not refilled one?
E5 error means cartridges are not readable.
When you refill your canon cartridge, especially for color one, it happens. (after 4~5 times of refills)
So you have to replace the cartridge with brand new one.
(for your additional reference, it doesn't happen to black cartridge)
So at least you can refill black...
If you would like to save money, try nozzle injection refill kit by ROADINK.
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.">
Apr 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
"WRONG CARTRIDGE" continues to flash on the screen.
I have experienced the "Wrong Cartridge" error about 4 times in four years. I have never bought a replacement print head. I do occasional printing each week. Typically the problem occurs after a color cartridge goes empty and the ink dried to the print head. The solution for me has been to remove the cartridges, remove the print head, place the print head in hot water in the kitchen sink (softens water based ink that has hardened)and then use a Q-Tip or tissue paper to clean the print head until it is nice and shiny. Reinstall the print head, insert ink cartridges that are not empty, let the printer cycle through a self-test, use the set button to accept vertical and horizontal print patterns and you'll be good to go!
If that doesn't fix it, you'll need to replace the printhead ($49-69 depending on where you buy it.
Oct 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon BJC 80 InkJet Printer Logo
142 people viewed this question
old marine
old marine
