Samsung LCD HDTV - Color Problems
Purchased a Samsung 52" 1080P LCD HDTV, model LNT 5271FX. Colors are just not right...flesh tones have yellow blotches throughout faces, deep blues have large black pixels in them, even pavement around race tracks (NASCAR races) will have yellow blotches in them...what to do? What's wrong with my tv?
  • ccmica Apr 17, 2008
    my samsung le40r74 semms to be suffuring from the same problem. Any help?
Voltage adjustment for y-sus board or power supply
Posted on Mar 17, 2008
Need to what panel to replace on my samsung hdtv
Please include the model# of the TV. This helps in dagnosing the problem.
Feb 19, 2016 | Samsung Televison & Video
The color has changed so that grass looks like burned out fields and flesh tones look sickly. the menu color options do not seem to do anything, and blues still look fine. help! Baseball games look...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems
Jun 25, 2011 | Televison & Video
The flesh tones are not flesh tones in my new lg hdtv. they are either yellow or purple. how do i fix it?
Only through the service remote, this can be changed. Contact service center.
Check the tint control option in the menu!
Refer user guide.
Apr 23, 2010 | LG 32LG30 32 in. LCD HDTV
Samsung HLP4663w. After replacing the Ballast, Bulb and Color Wheel (color wheel came without the CCA values and the Actuator and Index delay values) we still have the same color and picture problems. Do...
if the picture is blue green there is a jumper to be removed on the dmd board on connector cn810--the index delay should be between 40 and 50 for optimum color --or adjusted for best flesh tone also in the options the cw setting should be set for cw2
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Hello , I just purchased a 26" Toshiba LCD/HD flat screen TV today. The floor model had the nicest picture at Circut City of the other 26" TVs - but they were hooked up to receive HDTV. When I got it home,...
Yes, the newer flat panel TV's look great with HDTV but amplify the substandard analog TV signals.
I would compare the non HD to VCR quality. If that is what you are seeing then this is normal with non HD broadcasts (typically the channels 1-100).
Hope this helps, please rate my solution.
Jan 11, 2009 | LG 42LG50 42 in. LCD HDTV
Color went to grayish green, dull picture.
It ended up being one of the connectors on the composite cable. I did not know that the different colors came through separate cables. I do now, Thanks.
Dec 05, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Flesh tones and red colors
any hue adjustments usally relly cheap tv u got also hard to get good colers from it the lg one is nice i like samsung and sharp
go throw azll colers cheak dvd cables
Jan 06, 2008 | Insignia IS-LCDTV32 32 in. Television
Sharp Actius AL27 pixel problems
From what you described, it seems as though your LCD panel is going bad or the inverter board is bad. Does it change colors if you were to reposition (tilt) the LCD back and forth in either direction?
Nov 30, 2007 | Sharp Actius AL27 Notebook
Televison & Video Logo
2,310 people viewed this question
Top Televison & Video Experts
