Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer follow up question.........
Hello again,
I have the late 1990's Wurlitzer OMT CD Juke Box.....First off, thank you for reponding to my request. It seems that finding someone to come over to the house to look at the Juke Box is turning out to be more difficult than I imagined. I really appreciate your help.
To answer your questions, the disc spins each time it is placed on the player (perhaps for a few seconds), then it stops. It repeats this cycle 3 more times. (for a total of 4 times).
I believe the time it takes from being placed on the disc player to being returned to the carousel is a consistent 50 seconds. It doesn't matter what disc is selected or track number. The results are always the same. No music is ever heard, however I do hear a faint "single pop" noise coming from the speakers when the CD is attempting to play.
Could this be related to that strange 2222 display when the machine is turned on. I bought the Juke Box last Thursday and it worked fine for about 24 hours.
Thanks again,
John
    Problem Solver:
  • 5 Answers
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
Thanks Davejuke01 for explaining the "2222".
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The CD is placed on the laser unit and then spins it to read the Table of Contents (i.e. how many tracks it has). If it can't read the CD it tries again and stops. After 47 seconds it puts it back in the carousel. Therefore you either have a VERY dirty CD, dirty laser eye (clean with cotton bud and meths or head cleaner) or more likely your laser unit is busted. You can get a swap/replacement for a broken one from The Jukebox Doctor in Sheffield.
The 47 is the amount of credits you have left when the machine is set on freeplay. If you make a few selections you will see it comes down one each time.
The 2222 is CD 22 track 22 which you play more than any other track. (It's the Most Popular Track).
Posted on Mar 20, 2008
    Problem Solver:
  • 8 Answers
Ok a few things it could be.
Firstly as it is spinning it could be simply be that the optical assembly is wrongly adjusted or even dirty.
The other least likely scenario is a progamming error - did you do any programming to the jukebox when you received it for things like how many cds it is holding and free play etc?
The reason I favour the first scenario is because I had exactly the same problem (although mine was not even spinning). The two things I did were to toggle the service switch on the S&CC board then switch the power on and off then give the magnetic clamp above the turntable a bit of a tap and voila it started working again! Not exactly scientific I know.
BTW do you have the manual - if not then here is the link for it to help you further.
http://www.flippers.com/pdfs/OMT_CD_Operating&FieldService_22.pdf
This will also help you do any functional tests (chapter 13) to help you get to the bottom of the problem.
Posted on Mar 18, 2008
My Box Was Damaged in shipping, Where can I buy Replacement Plastics and Bubble Tubes.
If you google for "cd jukebox parts" you can find a list of suppliers of all kinds of jukeboxes. You check with a few that work for Wurlitzer and I think you can find what you need.
Mar 16, 2015 | Wurlitzer Jukebox 1015 One More Time...
I need to find a place to buy replacement parts for omt wurlitzer jukebox that plays 45's. Thanks.
If your jukebox is ineed a Wurlitzer then you can order parts via a dealer, if the jukebox is by another manufacture then I suggest you look on the two following websites:-
www.victoryglass.com & www.happ.com for used parts www.jukeboxparts.com or in the UK at www.jukeboxparts.co.uk
Regards
Alan Hood
ami-man
UK
Feb 04, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer omt K99 the cd will stop during play
I seem to be having the same problem and all signs point to the serial control board board Pt# 0046630 under the player. The symptoms with mine were randomly cutting off songs about 20 sec after song start and returning disc to carrier. It started mostly when juke was first turned on (cold) and then progressed to all the time and now display on cd board is dark only randomly coming to life then dead again. power on the sub transformer is good and when it comes to life player works well. I am sending the board to be repaired.
Feb 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
I did NOT have the "2222" display issue.
Solutions:
Mar 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer omt
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
Nov 20, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
226 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
