Question about Toshiba Portege M205-S810 Tablet PC
Installing windows without DVD
I need to re-install windows due to a disk crash.
The only optical drive I've used with this is a normal USB 2.0 DVD RW. The computer won't boot from this.
It boots fine from USB Floppy, but when you do >cd c: (or any other letter) it says invalid drive.
Any Ideas?
  • 3 more comments
  • One Man Band Mar 25, 2008
    The hard disk is being recognised fine when trying to boot from it, but when booting from USB floppy with a normal windows start disk, it will not change directory to the hard drive. As the bios does not support my USB 2 dvdrw, I want to know which optical drives are supported for booting. I belive a PCMCIA drive will do it, but I just wanted confirmation before I buy one. there are also tosh usb drives which are supported, but these are pretty hard to find.
  • snowdigger Mar 26, 2008
    I have the same problem.. my hard drive is hosed and I only have an external USB cd-rom but NO floppy drive. Is it true I'll have to buy a Pcmcia type cd rom drive?
  • benhusain Jun 18, 2008
    I want to re-install windows due to a hard disk crash.
    so what can i do??
  • Anonymous Oct 02, 2008
    No cd
  • Marty marty May 11, 2010
    earlier I responded to your newer post which did not include the new problem posted here..."it says invalid drive."...Please rate my earlier post as solved if in fact you still have this problem of ..."it says invalid drive.". This poses an entirely new and more serious problem.
  • Toshiba Master
  • 19,396 Answers
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Posted on Apr 15, 2009
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.
Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)
Step3: Set the target computer boot from CD/DVD or USB.
Step4:Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.
Of course, you can also finish Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
Aug 13, 2012 | Toshiba Portege M400 PPM40U01000E Tablet...
Forgot password, does not have cd rom drive, need to restore to factory settings. How???
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
My lenovo G450 is not installing windows 7 ultimate.I had windows xp and vista but cd is not taken on boot up although the cd is bootable and i have installed 7 on my desktop but not taking on lenovo G450....
The Lenovo G450 is quite compatible for Windows 7, there could be following reasons:-
1. The CD/DVD Drive may not catch the CD/DVD becuase of lens may gone dusty, clean the lens. 2. DVD/CD may be damaged due to scratches, try another CD/DVD 3. Check the Boot options from BIOS, it must be CD/DVD on first boot
Good luck, and do rate the solution if got help
Dec 10, 2010 | Lenovo Tablets & eReaders
Installing Windows XP OS from CD
I have been installing XP on Portege M200 laptops.
I use a usb floppy to install the latest bios update from Toshiba's support site.
After the update the laptop will boot from a USB Cd/DVD drive.
be patient the first part of the up date goes extreamly slowly but it seems to keep working and the install will work.
Apr 20, 2010 | Toshiba Portege M205-S810 Tablet PC
Can i reformat my eee 904 hd winxp without an external optical drive
Unfortunately not. Unless you know someone that can convert a thumb drive into a Windows install disk, you cannot format without an external CD Rom drive.
Oct 25, 2009 | ASUS Tablets & eReaders
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
2 Compaq TC 1100 - neither boots
Try first to clean you memory using the eraser and put it again. Then u can use flashdrive in installing your windows. It can be that your cd/dvd drive is the problem. Hope this can help.
Mar 27, 2017 | Compaq D70045-236 Tablet PC
Ix104c3 fails to start half way through loading xp
hmmm it appears that file maybe missing on the hard drive of the pc and when its restarting like that its encountering a blue screen of ***** because it can not load that system required file now there is a way to fix this but you can expect everything to be placed into the windows.old folder if done right but you will need a second pc to do this
First: https://www.fullversionforever.com/windows-xp-black-edition-latest/ download the file here but instead of placing the ISO image onto a USB drive with the program they say to use you can burn this file onto a disk using window's built in tool or IMGburn (built in way: right click on the ISO file and click burn image and this will burn windows XP BE onto a typical 700MB disk (WIN XP BE isnt a normal windows xp version but will be supported by MS up to 2019) plus the install will be like installing XP but just refreshing it long as you dont format the hard drive (EG: do not format during the install setup)
Second: install a well good known antivirus such as AVG or Sophos home antivirus
Apr 22, 2017 | Xplore Technologies iX104C3...
IBM ThinkPad X41
Afternoon,
I hope this helps?
To recover the hard disk to it's original contents, do the following:
Note:
1. If the optical drive is not attached to your ThinkPad computer during recovery, DVD software and CD-recording software will not be installed. To ensure that they will be installed correctly, attach your ThinkPad computer to the X4 Dock and install the optical drive in the Ultrabay Slim before performing a recovery ioperation.
2. The recovery process might take up to 2 hours.
Attention: All of the files on the primary hard disk partition (usually drive C) will be lost in the recovry process. However, before any data is overwritten you will be give the opportunity to save one or more files to other media.
Power the computer using the AC adapter and ensure a fully charged battery is installed before proceeding.
1. If possible, save all your files and shutdown your operating system.
2. Turn off the computer for at least 5 secounds.
3. Turn on your computer. Watch the display carefully. While the message. "To inturrupt normal startup, press the blue Access IBM button" is displayed at the lower left of the screen, press the Access IBM button. The Rescue and Recovery workspace opens.
4. Click Restore your system.
5. Click Restore my hard drive to the original factory state and then click Next.
6. Follow the instructions on the screen.
7. When the recovery process finishes, press the Enter key. Your computer will restart with the pre-installed operating system, drive, and software.
Dec 02, 2008 | IBM ThinkPad X41 Tablet PC
Can't install XP
It could be bad RAM, but it could also be drive error.
Try running chckdsk.exe
If the drive is ok, try copying the win xp cd to the HD and try to install from the HD
First, you need to copy your Windows XP Setup CD contents to your harddrive. I recommend saving the xp install files/folders to a separate partition than where you're going to install xp to (ie. have setup files at d:\winxp\ and then install xp to c:\ drive)
restart your computer with the win 98 boot disk
at the command prompt change to the drive with the xp files
ie. cd d:\winxp\i386\
type winnt to start installing
install as usual
Dec 28, 2007 | ViewSonic Tablet PC V1100
Toshiba Portege M205-S810 Tablet PC Logo
795 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
