Brother MFC 420CN All-In-One InkJet Printer Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Erase memory from fax
How do I erase teh memeory from my fax machine? when trying to send a fax, I get an error message "no memeory". How do I corrct this problem?
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Mar 17, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1709987
Points
8129
Unplug the unit and take any battery's out. then plug back in
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
1helpful
I can't erase the faxes I already send
Hi There,
While not as popular as they were before the Internet became a principal means of business communication, fax machines are still an essential item in many offices. They are particularly useful on business documents when a signature is needed. Canon makes a number of fax machines that use both ink-jet and laser technology to receive and print documents. Most fax machines store incoming faxes in memory so you can reprint them, but occasionally the memory becomes full resulting in an error message. Your Canon fax machine's memory can be cleared quickly and easily so you can start using it again.
Instructions
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
1helpful
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
2helpful
MFC 440-CN out of memory error, fax memory is full I cn't send any more faxes, I called Brother tech support they told me that there is no way to clear the memory, that I had to leave the printer unplugged...
Try this :
To resolve this situation do the following:
1. If another operation is in progress (example: receiving a fax,
printing, etc), press STOP/EXIT, wait until it's completed and then try
again.
2. Clear the machines memory. This can be done by turning off Advanced
Fax Operations.
a. Press MENU.
b. Press the UP OR DOWN ARROW key to choose Fax.
c. Press OK.
d. Press the UP OR DOWN ARROW key to choose Advanced Fax Operation.
e. Press OK.
f Press the UP OR DOWN ARROW key to choose Fwd/Page/Store.
g. Press OK.
h. Press the UP OR DOWN ARROW to choose Off.
i. Press OK.
j. Press STOP/EXIT.
If received faxes are left in your machine's memory when you change the
Advanced Fax Operations and a backup copy has already been printed, the
LCD will ask:
Erase All Fax?
Yes - Press 1
No - Press 2
Advanced Fax Operations and a backup copy has not yet been printed, the
LCD will ask:
Print All Fax?
Yes - Press 1
No - Press 2
# If you press 1, faxes in the memory will be erased or printed before
the setting changes.
# If you press 2, faxes in the memory will not be erased or printed and
the setting will be unchanged.
k. Try your operation again.
Good luck...
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
Norman Weimar
Norman Weimar
k24674
