Question about Toshiba TEC B-472 Thermal Label Printer
How to say to the priter we don´t use ribbon
I allways get the error:
Ribbon Error
but i want to use thermical direct,.. whitout ribbon.
how can a i change that?
thanks
  • HM-MBF Apr 03, 2008
    I have the same problem with TEC B-472.
    Print Method: Direct Thermal.
    I am not using the ribbon paper, but I got the ribbon error.
    When trying to print or feed.
  • anonymousffs Mar 24, 2009
    Exact same problem. The given solution is not helpful, it just parrots the manuals. The error occurs even when test printing from the printer's front panel.
  • 300 Answers
If you are printing in direct thermal mode (without a ribbon):
· Check your software settings and make sure that the print type is 'direct thermal'. If your software package requires the use of a Windows driver, also make sure that the driver is set for direct thermal printing.
If you are printing in thermal transfer mode (with a ribbon):
· Check your software settings and make sure that the print type is 'thermal transfer'. If your software package requires the use of a Windows driver, also make sure that the driver is set for thermal
transfer printing.
Check to see if there is any dirt on the ribbon spindle gears or on the ribbon motors. For the latter
you will need to remove the electronics cover. If there is dirt in either of these areas, try vacuuming around the motors and/or the spindles to remove as much of the dirt as possible.
Posted on May 16, 2008
Zm600 error message ribbon out
If you are using ribbons make sure your Ribbon is covering the ribbon sensor (located behind the Printhead on the inside of the media path. Looks like this.
If you don't have a ribbon change from Thermal Transfer to Direct Thermal in the menu.
Jun 11, 2014 | Zebra ZM600 Printer
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the...
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Apr 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
Jul 27, 2008 | Zebra Z6M Plus Thermal Label Printer
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
647 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
