Question about EliteGroup P4M800-M7 Motherboard
After Bios Upgrade P4M800-M7 V1.0 dont Boot
Hello Iqbal, very thanks, bus
Using the E052211.ROM and change BIOS setting Advanced Setup -> DRAM driving item to High can boot, but windows was colorless and crach in any minutes.
When test your soluction don't boot. Any configuration to do?
Very Thanks.
Try and go back to an earlier upgrade as this sounds like it might have hurt your original MASTER BOOT RECORD. If you find one that works quickly copy your MASTER BOOT RECORD and save it.
Posted on Mar 25, 2008
Stuck at Motherboard splash screen
your stuck at the boot from DVD, you must boot form C to finish installation.
Jul 27, 2014 | EliteGroup P4M800-M7 Motherboard
Select booting drive
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI = CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
If your computer won't boot without a password or you need a password to enter the computer set-up or change the settings, then you have a BIOS password set. BIOS is an acronym for basic input/output system.
The BIOS is the basic instruction set that teaches the computer how to access disk drives, keyboard, display etc. The BIOS is typically placed on a ROM chip in the computer hence the term ROM BIOS.
The ROM BIOS allows the computer to boot itself. The BIOS is required to boot the computer. Thus, if the BIOS is password protected, the computer will not boot (or you will not be able to enter or change the BIOS settings.)
using the arrows keys scroll to Advanced Bios Features change the first boot device to cd rom press escape the F10 save to cmos to restart
BIOS is a software program that controls basic functions in your computer, such as boot order, keyboard control and how your processor interacts with memory cards
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to advanced bios features press enter to change boot devices
press f10 to save to cmos escape then restart your computer
if you need to change any of the settings using the arrow keys if you have made any changes that has compromised your computer
you can go back and load failsafe or optimised defaults
hope this helps you
May 28, 2012 | Computers & Internet
What is a bootable disc (bios)
The BIOS is the basic instruction set that teaches the computer how to access disk drives keyboardisplay etc The BIOS is typically placed on a ROM chip in the computer hence the term ROM BIOS.
The ROM BIOS allows the computer to boot itself. The BIOS is required to boot the computer. Thus, if the BIOS is password protected the computer will not boot
bootable disc being the installion cd
hope it helps
Jan 16, 2012 | Computers & Internet
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
I can't instal windows xp on this bord msi p4m800-m7 rev:3.1
Did you install the motherboard drivers first?
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=95
Did you also go into BIOS Setup, and in Boot Options, set the first boot device to CDROM?
Regards,
joecoolvette
Jul 17, 2011 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
SYSTEM SWITCHES ON AND DETECTS ALL THE HARDWARE BUT WONT GIVE ME THE "PRESS ANY KEY TO BOOT FROM CD-ROM OPTION"
Some computers allow you to select an alternate boot device by pressing the F12 key as you boot up.
If your computer doesn't have this option then go into the BIOS configuration and change the boot order and make the CD-ROM the first boot device and the hard drive the second boot device.
Aug 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
After Bios Upgrade Computer don't Boot
hmmmm you have currepted your DRAM, no problem try this file i think it will fix your problem.
Click here to download.
and try to write.
Thanks
Iqbal
Mar 16, 2008 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
130 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
