Question about Kenwood KDC-MP435U CD Player
SAT Radio installation
1) How do I connect and get the SAT radio to work. Do I need the SIR-KEN1 and an antenna or is already in this unit since it says it is SAT Radio ready?
2) How do I obtain the ESN code?
    Problem Solver:
  • 5 Answers
What you need is the SCC1 (Sirius tuner) and the KCA-SR50 (Kenwood adapter). The ESN number can be found on bottom of SCC1 before you install it.
Posted on Mar 20, 2008
Sat nav and radio not working
Good Afternoon Michael
Sounds most likely to be an antenna issue. Most everything going into the radio needs an antenna to be picked up. Sometimes, a station or two might still be heard above the static if they are local and fairly strong signals.
If you can get normal sound from other inputs, like MP3 players or CDs, then the amp and output parts of the unit are fine, and it's an issue of getting an input signal to use.
If you have the tools, pull the stereo head unit from the dash and make sure the antenna input cable(s) are firmly in place. Likewise, depending on location, you can likely get to the base of the external antenna, where the other end of the cable plugs in, and make sure it's in snugly.
lacking the tools - you can talk to your dealer or a local car audio place. They'll likely have the tools, and a check for antenna cable connection would not likely be too expensive or time-intensive.
Good Luck!
Nov 18, 2015 | Mercedes-Benz C-Class Cars & Trucks
What does fuse called radio-b do?
If your unit has digital display as most do now, RADIO-B will supply constant power to power the units memory so it can remember the preset channels, starting volume etc. The power antenna is usually controlled by a separate wire from the unit (normally blue) this wire supplies a low voltage signal to the antenna, The antenna will also have its own power supply and earth at the base of the antenna, the problem could be there. depending on the antenna, some have a controlling relay that is separate, again another possible source. there will also be a fuse in the main fuse box. These will all need to be checked, along with connecting a power source to the antenna to ensure the antenna does actually work.
Feb 23, 2013 | Cars & Trucks
My sirius radio sportster works sometimes and others doesn't
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
Oct 01, 2009 | Sirius Satellite Radio Sirius Sportster...
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
Do I need a Sirius radio antena for a MBB219
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Jun 03, 2009 | JBL Mbb 218 Cd Radio
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
Sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Oct 01, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Mar 25, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
Kenwood KDC-MP435U CD Player Logo
243 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
