Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air JCD2389GTW Refrigerator problem
My freezer size of this appliance seems to work fine but the refrigerator side is warm. I suspect that the auto defrost system may be the culprit. Any ideas?
Freezer side seems to be working fine but the refrigerator side is getting warm especially at the top. Seems to be cooler on the bottom but this may be because the colder air is heavier. I don't know. Thinking of just chucking it out and buying a new one.
  • dadkins May 25, 2008
    The freezer side works well. The cooling side is not cooling. There is a small slide passage door at the top left side of the cooling side which is adjustable to pass cold air from the freezer to a compartment in the door. It generally blows a heavy draft of air when opened. It is not working. Does this issue relate to the problem? Del
  • 828 Answers
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Posted on May 23, 2008
Where's is the defrost drain for Jcd2389gt
Click Here=> Maytag JCD2389GTW Freezer Compartment is where you see the drain begin inside freezer and behind panel labeled location 20. The other end of defrost dran comes out below refrigerator and near condenser fan motor. How to clean a defrost drain Click HERE=> How to Fix Fridge Water Leak, Thanks Sea Breeze
Much more on this page=> Leaking Refrigerators!
May 05, 2012 | Jenn-Air JCD2389G Side by Side...
Freezer is running at a warm temp- cannot maintain a constant temp of -1. Refrigerator is fine and working properly. Anything I can do before calling a repair mn?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Jenn-Air JS48SEFXDA Stainless Steel Side...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-air fridge not working
If the back panel of the freezer is Iced up you may have a defrost problem. or the damper between the freezer and thr refrigerator is closed.
May 19, 2008 | Jenn-Air JFC2087HRP Side by Side...
The auto defrost timer was broken, so my refrigerator repairman replaced it. The part is about $60. The bigger expense was the labor getting to the timer, which is in the upper right hand corner of the refrigerator within the plastic casing that houses the temperature control levers. He then had to remove the panels of the freezer and defrost the coils with a blow heater. It took several hours.
Feb 28, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Feb 22, 2008 | Jenn-Air JCD2290HES Side by Side...
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Guys first make sure the freezer fan is working, then remove the lower rear panel in the freezer and inspect the coil for excessive frost, if there is than use a hair dryer to thaw coil completely. If you guys then post your full model #'s i can help with figuring out why the defrost cycle isnt working.
Jan 10, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
211 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
