FixYa.com
Tags:
TV Combos
Generic problem for all TV Combos
PANASONIC MODEL TC29PS78W
posted by primal on Mar 17, 2008
NO SOUND
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 24, 2008
Not Rated (0)
Shuttle83
Rank:Wiz Wiz
Rating: 84%, 607 votes
Hello primal,
First check your TVs configuration Menu, check for mute and volume controls, make sure these are set to their default setting. Then check to see if any of the other audio outputs are working. If they are then you just may have a loose solder joint at that one audio output I/O port. However if no audio is present on any of the other ports, you may have a defective audio output processor. If the audio processor is defective, it will have to be replaced. I would suggest that you take the TV to a qualified TV repair shop and have them give you an estimate of the cost of repair, and have them do the repair work on the TV. It should not cost much depending on the policy of the shop you take it to.
I hope this helps,
Thank you,
Shuttle83
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Audiovox VE-920 9 in. TV/DVD Combo Audiovox FPE1078 7.8 in. TV/DVD Combo Memorex MVD2013 Combo Memorex MVD2019 19 in. TV/DVD Combo Memorex MVT2090 9 in. TV/VCR Combo Memorex MVT2137 13 in. TV/VCR Combo Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Can you Help with these TV Combos problems?
TV Combos
DVDs all of a sudden play only...
I have a 13 month old (figures,... Answer This...
Toshiba MV13Q41 13 in. TV/VCR Combo
Big black box
The screen is almost completely... Answer This...
TV Combos
Toshiba TV/VCR/DVD combo
It turns itself off after about... Answer This...
TV Combos
JVC Big Screen
I have a 60' Jvc big screen.... Answer This...
TV Combos
dvdrecorder/vcr
hi i have a 3 yrs old dvd... Answer This...
Repair Service
Find TV Combo Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
