Question about Philips DVP5140 DVD Player
PHILIPS DVP3028 HAS NO VIDEO IN VIDEO OUT
I HAVE PHILIPS DVD DVP3028 PLAYER BUT IT HAS NO VIDEO OUT...IN VIDEO OUT PUT MODE AND IN SETUP OPTION NO ACTIVE PREFERENCE MENU...... PLEASE SOLVE MY PROBLEM.....
  • 1 more comment
  • MSBROS Mar 17, 2008
    NOW IT WORKING ON Y PR PB MODE PLEASE EXPLAIN ME........
  • Anonymous May 17, 2008
    my dvd player is working good but there is problem with composite video signals , it is no found.
  • MSBROS May 11, 2010
    HAVE PHILIPS DVD DVP3028 PLAYER BUT IT HAS NO VIDEO OUT...IN VIDEO OUT PUT MODE AND other port are ok.......
  • 8,596 Answers
If you have a Green, Red and Blue (Component) cable connected to DVD player, then it will work in YPbPr mode - otherwise it will work in a different mode.
Posted on Mar 20, 2008
I would like to know the code for my dvd player its a RCA please
Hello
Setup code for RCA with Philips SRP2003/27 is:
2351
[1] Make sure the receiving device is able to
respond. E.g. when you try to repair the Play
key for your DVD player, make sure to insert
a DVD into the DVD player otherwise the
Play key is not able to function.
[2] Select the device
that you wish to
operate (e.g. DVD).
Press the (DVD) device
selection key to
select DVD.
[3] Keep keys (1 & 4) and
pressed
simultaneously for 5
seconds
The red Setup
light lights
up. The remote control is now in setup
mode.
8 EN
[4] Press and hold the key that does not
function and immediately release it when
the device responds.
* If the key still does not function as expected,
try pressing it again for a longer period of
time.
[5] Press the (DVD) device
selection key twice
to save your settings
and exit setup
mode.
When no key
is pressed for 5 minutes or more, the
remote control will exit setup mode,
automatically saving all your settings.
OK.
Aug 15, 2011 | Philips SRP2003/27 Remote Control
My dvd player is asking for a password. I have no idea what the password is. I have a Phillips Mode DVP3982/37.
Try using the code 136900. If this password works, access the general setup menu using your remote, and chose the Disc Unlock option.
I understand this frustration, and truly hope this helps.
Dec 21, 2010 | Philips DVP3982 DVD Player
My Philips 634 DVD player needs a password. Any ideas?
Try the passcode 136900. If your DVD player accepts this code, then access the menu with your remote, and under the general setup menu, chose the Disc Unlock option.
Hope this helps!!
Nov 19, 2010 | Philips DVP5960
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
I wanted to know why i dont have color on the dvd's i put in my player
Go to the menu for the DVD player and look for RGB mode. If it is set to RGB, try changing it to another option, if not, change it to RGB. This has helped me on numerous occasions and the correct mode to use depends on the type of TV, cable, socket, etc..
Nov 15, 2009 | Philips Magnavox DVD/VCR Dual Player
How to convert my Philips DVP5990 to play PAL?
Press SETUP
Use the arrows to highlight Video Setup Page
Select TV Type - change it to PAL
There isn't a way to view PAL and NTSC at the same time with this player, but you can always go to the video setup page and switch between the two. Restoring the player back to its factory defaults will automatically switch it back to NTSC.
-Tha Mp3 Doctor
Feb 13, 2009 | Philips Televison & Video
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips dvd player
Turn off the night mode on the Philips:
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
Jul 20, 2008 | Philips DVD 622 DVD Player
No video in my philips dvd622
Check if you have not accidentlychanged to progressive mode which can cause this proble.
Are you connected to TV using Composite video out?Try connecting using S-Video or DVd (component inputs).
Do provide feedback and rate this solution.
Samir
Mar 26, 2008 | Philips DVD622 DVD Player
Philips DVP5140 DVD Player Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
